width on the rear of 93 saleen??
ive noticed the rear wheels stick out further than the fronts on my 93 saleen.has anybody ever put in a set of stock length axles to pull the rears in more under the car??
front brake??
im wanting to upgrade the front brakes also.is this a sn95 spindle?if i put a set of baer brakes up front,will this spindle work?also will the 93 stern wheel clear the 13"brakes??thanks,william..
Don't know about the axel's, but you have to have a minimun 17 in. wheel to clear the rotors and calipers on 13 in brakes. By the way the rear axel's are from a lincoln mk.7 on the foxbody saleens, why would you want to change.
See Ya Bill |
Here is a good read on how to use stock length fox axles(Ones from Left side Ranger or right side Aerostar) with the Saleen/SVO style calipers. Requires a little grinding but pretty straight forward.
http://www.wcfords.com/articles/tech.../reardisc.html |
you can upgrade to the 95 spindles and they will work fine. that is what I did with my saleen alcon calipers. Also I think that Baer sells a kit so that you will not have to upgrade to the sn95 spindles.
1993 |
