Help: Electrical issues after new speakers & Saleen sub
Just installed a Saleen Subwoofer and 4 new 6x8 speakers. Everything worked great for about 30 minutes... I turned the headunit up a little and it lost power. Additionally, the windows will not roll up either. I'm not sure what else is/isn't working. I was curious if anyone had any experience with this before, or knew what to address first
Mirror Caps, MRT Hood Struts, JLT Catch Can, Kooks LT Headers & Catted X, JLT Series 3 CAI, Bosch Injectors, HTO Plugs, 3.4 Pulley, KB Boost-A-Pump, SCT X3 Tuned by BRENSPEED, Chicane Brace, Pioneer AVH-P8400BH, White Extreme Splitter & Diffuser, MGW Shifter, Raptor Shift Light, 6K HIDs & LEDs, Stealth Bulbs, Steeda X-Brace, Corsa Sport Mufflers, Whiteline Watts Link & Rear Sway Bar, Slotted Rotors Front & Rear, 281 Grille, Dipstick, & Radiator Cover, GT500 Fan |
Just figured out it was a blown 5amp accessory fuse... Replaced it and it popped again. Now I have to figure out why. Do any of you know if the power consumption of the sub is too much for head unit to handle?
So your head unit shouldn't be powering your sub. So if it is there's your problem. My guess is that there a wire shorting out somewhere most likely near the amp on the sub.
Thanks Jason. Where is the easiest point of getting through the firewall to the battery?
not sure if this helps.....but just in case....
https://www.mossmustang.com/graphics...m/057-795z.pdf
2008 S281 S/C Convertible #12c ("c" stands for Canadian made Saleen version) |
What size gauge wire are you going to use?
The wire in the harness looks to be 10awg. It's only a 150w sub, so it should suffice... There's no way to upgrade the cable harness either
10 gauge isnt that bad.
