Good Fuel Pump For My 99 S-281 SC??
Well today I finally finished my car and actually went to start it and it didn't start. :/ I realized that the stock fuel pump probably went out because I put 5 gallons of gas in there and there is no fuel going through the fuel rails, the motor turns and turns but wont start, and now I don't know what kind of aftermarket fuel pump I should go with.. Any ideas? I seen several people use the svt focus pump and the ford gt supercars pump.. Any help will be greatly appreciated. Thanks.
'99 MUSTANG SALEEN S-351 #37 "FASLEEN" '99 MUSTANG SALEEN S-281SC #201 "SLOLEEN" '99 MUSTANG SALEEN/COBRA S-281 #320 |
Either of those pumps are great if your stock or aren't planning to upgrade the supercharger.
2017 Z06 stock for now. |
focus fuel pump will satisfy your needs...
I recently upgraded from the Series I blower to the Series IV blower and thats how it will be staying for the rest of its life cause I like keeping the stock Saleen look. Check out my sig for all my mods if you have a chance and let me know if you still think either of thise pumps will still hold up.. Thanks Also do I have to modify the Fuel Pump Delivery Module when upgrading pumps?
Jim Jr. sold me an 05 + fuel pump for my setup. Said it is plenty. Might want to talk to the guys at JDM.
I'm also running the 05+ mustang pump in my 99 along with 42 lb injectors,
fuel pressure rarely goes over 20psi even at full throttle... |
I dont understand this. Properly tuned you should see about 40 psi fuel pressure without any boost. Then at wot it should go up 1 psi for every # of boost you run. Like if your running 10 # boost you should see a steady 50 psi of fuel pressure at wide open throttle. I would be concerned about running lean. Do you have a wideband a/f gauge ?
I used to see 40+ psi fuel pressure when I was still running the stock 30lb injectors. Under WOT, it would climb to 50+. Turns out the replaced PCM was bad and instead of putting in a good PCM, the previous shop just turned off the O2 sensors... car would go into open loop and stay there, A/F was like 9:1...
Took it to a different shop, installed the new fuel pump, 42's and retuned the car, it rarely goes over 20 PSI even at WOT, I don't recall seeing it above 20 but it's possible... The car runs dramatically better and doesn't kill you with exhaust fumes anymore. A/F is 12:1 now, made 337RWHP. |
So, I took 'the old car' out this weekend, and I stand corrected...
Car is normally running around 20psi. Took it out on a back road and nailed it and watched the fuel pressure gauge... started at 20, boost kicked up to around 9 and the fuel pressure went up to 30 and held there until I got off it. Pretty much in line with what you said other than my 'base' fuel pressure seems to run around 20psi and kicks up to around 25 cruising on the highway. Quote:
if you want to go with the dual pumps, you need to also replace the tank since the bucket was different enough that it wouldn't just drop in the non-cobra tank. YMMV... |
So I finally ended up buying the SVT Focus pump and I was wondering if I have to drill holes in the basket like alot of people talk about doing on other forums??
Not sure, but I have to replace my pump as well and I was under the impression you could replace just the pump assy and not the whole pump, sending unit, etc... I was going to go with the 2005 pump and etc, but it was like $495 where as the Focus pump $155.
I just went ahead and replaced the pump and used my old assembly. I paid $235 for mine though. :/
If you are going to be running a stock series IV supercharger I would either go back to a stock pump or a focus pump. Both of these pumps are good for what you are running. A Focus pump would allow for some growth though.
Depending on where your fuel pressure gauge is getting it signal from will make a difference to your reading. If you datalog and compare it to the gauge you will see a difference. 20psi on a gauge could be 30-40psi at the PCM. The PCM maintains the fuel rail between 40 and 50psi no matter what but the volume is increased by making the pumps pump faster with more fuel by the FPDM.
Speaking of pumps, I was trying to order one like 30 days ago from Haney Motorsports. I tried to call them to no avail, tried to Email them, but got no response. Anyone know if they are still in business? I'll have to source another place to buy the pump, but it kind of sucks as the pump was like 130 then, went up 2 weeks later to 155, now its 200 bucks.
