Q: Tune necessary with mid-pipe swap?
I have an 06 supercharged saleen convert that is bone stock. If I change the mid pipe to a high flow chatted pipe, do I have to get a tune? I have the stock magnaflows . How much louder will it really get?
You'll likely get a Check engine light with high flow cats. A tune will turn off the rear O2 sensors or you can try mil eliminators but they don't always work. I had the high flow cats with the stock Magnaflows. It was definitely be louder.
I have never had to retune with high flow cats. Only need tune of you remove cats.
You do NOT need a re-tune for high-flow cats, nor without cats either.. If you remove the cats altogether, you just have your rear 02 sensors turned off by whomever you purchased your hand held programmer and custom tunes from, or install a pair of MIL eliminators..
You only have to get a re-tune, if you upgrade to long tube headers !
Saleen series VI S/C - 39lb injectors - 3.6" pulley - Eibach pro kit springs - Borla ATAK mufflers - Pypes cut n clamp X mid-pipe to OEM cats - Firestone Firehawk Indy 500 Tires 275/40/18" square - GT500 strut mounts - Hurst short throw shifter - CFM billet oil cap breather - UPR 4 chamber catch can - Eibach camber bolts - OEM GT500 18x9.5 wheels - Koni adj sport struts/shocks - BMR poly adj panhard bar - Saleen extreme 98mm stock airbox - Autolite HT0 spark plugs - JDM 91 oct performance tune. |
I ran a high-flow catted Mac Prochamber and never got any check engine lights nor emission lights whatsoever !
A mid-pipe with high flow cats does not require a re-tune. I have a JDM tune. I replaced the mid-pipe with a JBA catted X. No check engine codes and the sound got a little better. Then I put on BBK ceramic shorties. Again no re-tune required and no check engine lights; but the sound got MUCH better. Deeper tone at idle, and much better sound overall. You can get louder and deeper tone with long tube headers or an off-road, no-cat mid-pipe; but as others have posted, it will most likely require a re-tune. You may also lose some boost with long tubes. Also, keep in mind you will probably get some drone if you go cat-less. I have zero drone with my set-up.
06-115 / S281 3V / SuperShaker / AirLift / Zenetti Baron forged / JDM / 3M Liquid Copper Wrap Last edited by sidvicious; 06-13-2015 at 11:56 AM. |
Concensus
My thoughts are to either go with a catted prochamber or a magnaflow catted h pipe
Which is deeper and louder? |
Mac discontinued production of their catted ProChamber quite a few years ago and only offer their off road version without cats
