Old 08-31-2011
SALEENJAMES's Avatar
SALEENJAMES SALEENJAMES is offline
Default Best Air Intake System
What is the best cold air intake system for a 2001 SC Saleen with the series II blower?
Old 08-31-2011
disco's Avatar
disco disco is offline
maf adaptor and a 10inch filter is the best way to go.
00gt 10k on the clock saleen s4 blower and full saleen body kit. 2.76 upper, 42's , 90mm maf, 75mm tb, focus pump. high flow cats, stock gt exhaust, 31splines and 373's. best et without body kit was 11.9 at 116mph on et streets. 1.60 sixty foot. way more to come out of this combo sct tuned by me.
Old 08-31-2011
my system is kinda like that but its seems to be pulling too much hot air in from the motor
my motor setup:
Old 08-31-2011
disco's Avatar
doubtfull none of them give you cold air id worry about a bigger intercooler tank and keeping the air charge lower
Old 08-31-2011
OxfordS281's Avatar
OxfordS281 OxfordS281 is offline
nice engine! more pics!
Old 09-01-2011
the motor temp and cooler temp is low and stays low but tuner says its pulling hot ain in. idk figured id ask.
Old 09-01-2011
disco's Avatar
its called summer
Old 09-01-2011
like i said i was just wondering and seeing what people thought. car still runs great.
Old 09-01-2011
http://www.mustang50magazine.com/featuredvehicles/m5lp_0804_2001_saleen_s281_mustang/index.html
Old 09-01-2011
SonicBlue's Avatar
SonicBlue SonicBlue is offline
http://tunableinduction.com/9604_supercharged.htm
Second intake down (System #4SC-B) is built for your year Saleen SC stang.
'03 SC Coupe (1 of 2) 380hp / 400tq @ 12lbs boost 18x10" rear wheel option
13" Saleen Brakes ◄ Chicane Intercooler ◄ 2.875" VI Xtreme Pulley ◄ 4" polished CAI
75mm TB ◄ Bassani Exhaust (Mid Length Headers, X-Pipe, Mufflers) ◄ FRPP 3.73 gears
90mm MAF/42lb Inj ◄ Ford GT Fuel Pump ◄ Rear LCA's ◄ Subframe Connectors + more!
Old 09-01-2011
know of anyone whos used it?
Old 09-01-2011
SonicBlue's Avatar
I did for a while before I got a custom intake made.
Old 09-01-2011
any pics of it on? and what your current one looks like?
Old 09-01-2011
Mike-C Mike-C is offline
excuse the dumb question I have been a 03-04 cobra guy for years and never had a Saleen or a 2v gt anyway when ordering a cai for a 02 s281 sc. do I just order one for a 02 gt? I can't seem to find many for a Saleen. thanks and sorry for the highjack.
Old 09-01-2011
Pic of motor? Sc or na?
Old 09-01-2011
2002 s281 supercharged
Old 09-01-2011
1hot281's Avatar
1hot281 1hot281 is offline
SOEC Member (Inactive)
my motor setup:
Homemade heat shield;
cheap plastic waste bin
foam pipe insulation
dremel
ruler
scissors or snips of some kind
http://www.nloc.net/vbforum/gen-2-li...ir-intake.html
BOOM. That just happened
My mechanic told me, "I couldn't fix your brakes, so I made your horn louder..."
Old 09-01-2011
02S281 02S281 is offline
JLT or a KB CAI.... both are good, both are $200. Im in the same boat as you, I hate having mine in the engine bay. JLT also sells a heat shield if you wanna do that also.
Old 09-02-2011
RISALEEN281 RISALEEN281 is offline
Anderson Power Pipe.
Pick up a couple PSI and some colder air. The filter is in front of the passenger tire, right where the side vent is, on the front bumper cover.
When Anderson was building my car, they used it as a prototype car to build that Power Pipe.
2004 S281 #50 - 492 rwhp, 494 rwtq (Sold)
1997 Viper GTS #123 (Sold)
1996 S281 #63 (Sold)
2000 S281 #108 (Sold)
1993 Cobra #2302 (Sold)
Old 09-02-2011
JLT said that they do not make an application for the seriers II blower for saleens
Old 09-02-2011
OxfordS281's Avatar
if you get a series 4 inlet, you can put it on your series 2 blower, allowing you to run a JLT intake, this guy did it his website is www.bluegt.com anyway, here are some pics, what you need is on the left, what you have is on the right...
what it looks like installed...
Old 09-02-2011
Thats whats on my car, a series IV inlet.
Old 09-03-2011
Who sells the series IV inlet?
Old 09-03-2011
SonicBlue's Avatar
So is it safe to say that the Techo Intake will work on a SeriesIV then? hmmm wonder how that would do?
Old 09-03-2011
OxfordS281's Avatar
good luck finding one, ebay, craigslist, who knows. its gonna be hard to find just the inlet, without the blower.
Old 09-04-2011
03cobra456 03cobra456 is offline
what kit is this and who makes this?? i was just about to order the jlt but im not a fan of the fender design
Old 09-04-2011
The intake will work, but remember it is made to use on their complete system, so there might be clearance issues with the fire wall and issues hooking up the EGR system. EvilIgloo is using this on his Series II, so you might want to talk to him first as he had to "modify" his firewall and I don't think he ever got the EGR issue worked out.
Old 09-04-2011
OxfordS281's Avatar
he did a EGR delete... 03cobra456... what does your engine bay look like, if you dont like the fender well, why bother changing it, what do you have now?
Old 09-04-2011
is that the tork tech kit oxford? its not that i dont like it, i just like the look of the open filter with a heat shield like my 03 cobra has
Old 09-05-2011
Rayder_K Rayder_K is offline
Love the car buddy. The engine is beautiful
Old 09-05-2011
The inlet, from the back of the blower to, and including, the filter is Tork Tech. However, Tork teck makes a whole kit including the inlet, and a new lower intake assembly... and a blower if you like. The lower intake isn't designed to use the Series I or II blowers. You should check out their website: http://www.torktech.com/. I spoke to them on the phone once and they are very helpful.
On Evil's car, he did have to cut the firewall to get the intake to fit. Just a small square though....
The last I spoke to them, they were going to offer a heat shield with their kit. The entire kit, blower, intake and inlet requires slight hood modifications with the stock GT hood and maybe the other Saleen hoods as well, but not positive about that. The Tork Tech rep said it should clear my E-hood.
Old 09-08-2011
lr281 lr281 is offline
I own a '99 SC with the Series-I. Currently I have the Chicane intake, but I want to switch to a fender based CAI. What is a good one that will fit my car and do I need a re-tune after the swap/
LR281
Old 09-08-2011
OxfordS281's Avatar
you wont need a re tune, just keep the same maf and you will be okay, as for what to use on the series 1, idk but the chicane piece is a good piece, probably worth some money id imagine!
Old 09-12-2011
eviligloo eviligloo is offline
They do offer a heat shield with their kit but I didn't end up using it because of clearance issues with the LFP supertank. They told me straight up that the heat shield on most air intakes doesn't do much.
And if you want the tork tech kit...werecow is right. You can forget using your stock GT hood or S/C hood without cutting into it or replacing it. That was the main drawback for me doing the entire kit.
youa likea da pics of tha intake-a?? (italian accent)
07 Porsche 911 Turbo
02 Saleen S/C Speedster
3.73 gears
Chicane 66mm Pulley
SCT custom tune
SVT Focus Fuel Pump
13" Brembo Brakes
LFP Heat Exchanger and Supertank
TorkTech Intake
SVT Cobra single blade TB
Chicane Intercooler
42lb injectors
90mm MAF
FPRP Aluminum Driveshaft
Maximum Motorsports LCA's, Subframes, Torque Arm, Panhard Bar, Steering Shaft, Front Control Arms and Aluminum Rack Bushings
MM Coilover kit with caster camber plates
Old 09-12-2011
OxfordS281's Avatar
http://saleenforums.soec.org/showthread.php?t=5487
  #36
Old 09-13-2011
02saleensc#2 02saleensc#2 is offline
James, I have the #4 system on my 2002 S/C. I added a few bolt ons and got a tune at the same time. I'm making like 60hp more than my baseline run with my add-ons. At the time I bought my #4 tunable induction, a lot of people went with it because it was one of the best intakes a few years ago.
  #37
Old 09-13-2011
any pics of this set up
  #38
Old 09-13-2011
SonicBlue's Avatar
I posted a link to that intake in post #11...
here it is again http://tunableinduction.com/9604_supercharged.htm
Pics of it on my Saleen before going with teh custom setup:
What I have now (Custom made 4" Polished intake):
  #39
Old 09-13-2011
i realy dont wanna change my piece behind my blower due to the custom paint and it saying saleen on it.
  #40
Old 04-24-2017
OxfordS281's Avatar
Did saleen use a specific EGR for the series 1 saleen?
1996 #222 1 of 21 in Moonlight Blue 1 of 8 with exact options
3:55's F-Leather 2 Point Chassis Brace
2000 #944 Performance Red 3:08's Chrome wheels, Supercharged, Floormats.
2002 #48 Mineral Gray Extreme
