Old 02-08-2015
killer454 killer454 is offline
Default New Saleen owner from Missouri w/ 97-0118
just wanted to say hi and just got my first saleen its a 1997 coupe #118 black on black and im 46 years old and I have a smile from ear to ear when driving this car I love it.
car is in perfect condition with 117000 miles not a crack in the dash or flaw in the black leather carpet looks real nice to.
i traded 2 atvs for it even up and this thing runs perfect cant beleave the power this thing has words just cant describe this car or the lope and exhaust.
just wanted to warn everybody killer454 will be a part of this forum for a long time im hooked on saleen power and performance
Old 02-08-2015
Welcome to the forum and congratulations on your new purchase!
Old 02-09-2015
00CobraR 00CobraR is offline
Awesome. Welcome.
2000 Cobra R # 253
2004 Saleen S281 SC #227 (1 of 1 Torch Red w/ factory 6 speed)
Old 02-12-2015
COramprat's Avatar
COramprat COramprat is offline
Now we need pictures
'03 S281 #0198
322HP 306TQ
4.6 WAP bored .030 over with DSS forged rotating assembly and billet main support*Comp 278AH Cams valve springs, retainers*6061 Plenum*FRPP 70mm TB*Victor Jr Intake*MSD Coils*JLT CAI*SCT SF3 *BBK Shorties and X*SLP PowerFlo CB*UPR FW adjuster and quadrant*FRPP 4:10's*Tri Ax*King Cobra clutch*Fidanza Alum Flywheel*Walbro 240lpm FP
Old 02-12-2015
Sc-rcode Sc-rcode is offline
Welcome from another fellow Midwesterner,enjoy the new ride!!
Old 02-13-2015
I will post pictures this weekend everybody
Old 02-13-2015
http://saleenforums.soec.org/showthread.php?t=6007
admisistrator dave found this add back in 2009 on my car this was great getting back history on this car I also called saleen before tradeing and verified the dash vin with them and it is a true saleen with all badges and plates.
back in 2009 the add says 15k on rebuild but im not so sure on that one car has aftermarket intake and looks to be running a cobra throttle body and aftermarket cams man does she lope and power is there in large quanities
dave told me I had 1 of 29 in black
1 of 17 with 355 gears
1 of 16 with chrome 5 spoke wheels
and my car is signed with a silver sharpe on the dash by steve saleen himself
Old 02-14-2015
mosaleen's Avatar
mosaleen mosaleen is offline
HI,,, we are having a Saleen group meet south of St Louis in May....
1st week. Info. will be posted soon.... Keep your eyes open....
3:73 gears, Watts link Gen II
Old 02-14-2015
Default ok guys here she is tell me anything you see on the car
its in the teens here and its cold natured the car has cams but don't know what.
it says zous on the intake manifold I was told I think that its running a cobra mass air flow sensor
I wish I knew if it had 99 pi heads
1997 s281 97-118
Old 02-14-2015
The aluminum intake manifold is the old Ford Motorsport 4.6 (M-9424-E46) unit.
Similar to the 2001 Bullitt manifold but different.
You should check and see if you the the old Ford Motorsport cylinder heads.
Front seats are aftermarket items. This car should have black leather 1994-1998 Mustang GT seats.
Front fender emblems are 2002-04 style. This car would have had stock 1996-1998 GT fender emblems.
The plastic fan shroud / radiator shroud is missing.
Headlights and turn signals are aftermarket. This car would have had stock 1994-1998 Mustang / Mustang GT lamps and turn signals.
Air intake is aftermarket.
As you know, stock 1996-97 strut brace was removed as well as the OE Ford hood insulation pad.
Appears to have a Saleen center dash gauge pod.
Old 02-15-2015
yes I have the original black lether seats and headlights in the garage with other stuff
2-panels he said it was the backseat deleate kit in a box
im going to take pictures today I have stuff that come with the car and cant findout what it is its a brace with 2 blue rods tried to figure it out but no luck.
thanks everybody
Old 03-22-2015
Default engine
engine runs perfect but burning real rich I think I got this figured out to aftermarket lopey cams bullit intake with cobra throttle body and 42 lb injectors but stock mass air flow sensor so im changing the mass sensor to one calibrated for 42lb injectors.
NO VORTECH INSTALLED YET
this car is setup for vortech supercharger has aftermarket fuel rails pump and regulator also dash gauge pod with boost and fuel pressure which is showing 38 at idle and never moves any advice on this I have not messed with regulator?
