Go Back   The Saleen Forums at soec.org > Saleen Mustang Discussions > 1994-1998 Saleen Mustang
1994-1998 Saleen Mustang For the SN-95 platform. Be sure to specify year, model and equipment if asking for help.
Old 11-21-2012
xmarine97 xmarine97 is offline
Default Power pipe on 1995 S 351
I installed a Anderson power pipe on my super chargerd S 351, now I have a question. On the the stock intake tube that goes into the back of the super charger was a brass fitting that had a rubber hose on it, that went to the oil filler tube that vented blow by from the oil filler tube to the intake tube on back of the super charger. Is this a stock item or was it added on my someone else. Also now where should I vent the blow by into. I hope I was able to explain this so you guys can understand it. Thanks.
Old 11-21-2012
ricksaleen ricksaleen is offline
SOEC Member (Inactive)
I worked up a simple catch can solution using the newer (07') S281E Saleen catch can system but modified and ran that little tube from the passenger valve cover stock right to the small catch can system. Looks good and is functional. If you look at some of the pictures I posted in the past (somewhere on this website) you will see what I did. Best I can do for the time being.
It was the easier way right now, though I think removing the entire valve cover stock and drilling a hole in the driver's side valve cover to put a true catch can system running hoses from each valve cover would be much better and more effective solution.
Old 01-16-2013
Saleen_S351 Saleen_S351 is offline
XMarine97, what fuel pressure regulator do you use or have upgraded too?
JMB
1998 Saleen Speedster (S351 SC) #14
Black on Black
