What do you think? - Intercooler fill plate
having my intercooler gaps filled tell me what do you think
not done yet just a prototype
Nice!
Looks great… I replaced my IC coolant lines with the chicane ss braded IC lines and it seemed to lower my IC temps a little. I think the rubber ones become restrictive a little over time. Also when I took the line off that runs along the firewall you could see where it was trying to rub through. Hate to see a coolant line fail on the road.
Muzzy 2004 281SC convertible #355 42# JLT cold air JDM SCT 93 oct tune 90mm maf 75mm TB Ported and Polished SC by PSE Mosaleen pulley sys Gaterback belt NGK tr6 @034 2.9 pulley Chicane SS braded IC lines SS Rear bumper inlays Carbon fiber dash kit and shift knob 1 bottle of water wetter |
hopefully getting it dynoed fri will post before and after @314.95 rwhp and 346.69torque before internal temp 180
Feel free to let us know how this works out. Please report your trials and benefits.
This is the best plate I have seen. I have seen a few bad attempts. Yours is one piece. Find a way to produce more than one at a time and make a few bucks... I would be interested.
I'm in for one (seriously)
Looks great! I'd also be interested in one!
Nice Job,
Probably much cheaper than going with the Chicane Part! |
when i did the first dyno it was early moring and 60deg. outside and temp was at 180 before had it dynoed after plate install and it was 80 deg. outside and temponly went to 150 so 30deg. drop (not too bad).working on making some more that can be just droped in .
I'll be in for one if and when you start making some. Keep up the awesome job. One question...Why are your temps so high? Mine never get above 130 on 90degree days. Bunch of upgrades? |
130? You must have an upgraded intercooler already. I see 160 just driving down the highway. After cool downs, dyno pulls would see 150+ up top. 150 is a key number. Timing really starts getting pulled after 150. Total of 16 degrees becomes 11 degrees at 6k rpm and 160 intake temps.
Is your coolant moving in you reservoir? When my pump lost it's prime I was seeing those temps, but after getting the coolant flowing again I see around 110 cruising on the highway and no more than 130 beating on it. My SC was put on after the second owner got ahold of it. So maybe I have a chicane intercooler and I don't know it. |
Thanks, I will check the pump. I know when my pump went bad on my 03 Cobra, the coolant overflowed from the reservoir. Maybe I will upgrade to the Lightning pump just for ****s and giggles to see what happens. Maybe my aftercooler is coated in oil. There are only 17k miles, so I wouldn't think so, but you never know. The heat exchanger is flawless without any bent fins.
the temp was intake temp on the dyno not coolent temp before the gauge read no more than 130 bc air was going around the intercooler now my gauge reads around 150 bc air is going through it not around and seems to be more accurate the dash gauge reads the coolent temp not the air
I see what you saying. Well get this thing made so I can buy one. |
So my point is, I guess it depends on what year your car is whether it reads air temp or water temp. |
Soo...I pretty much want to buy one right now so I can only pull the SC off once... :)
I compared my gauge to the readings i get from datalogging and they are the same.
03S281SC 03-269 Tunable induction CAI|2.8 pulley|39# Injectors|05 Mustang GT pump|90mm MAF|75MM BBK-TB|Mosaleen idler|MAC Long tube headers|Mac Off road X|LFP-H/E and tank|Chicane I/C|5gpm pump|373 FRPP gears|NT555R 305/35ZR1|MGW shifter|FRPP Alum driveshaft|N2MB two step 86-0087 03-269 S281SC 92 LX coupe 92 LX convertible |
I datalog to get accurate temps. Of course, I have a fuel pressure gauge instead of coolant temps.
