Old 06-20-2016
Dpredflag Dpredflag is offline
Default Q: 3.6 pulley or 4.10 gears?
I have a 08 Saleen RF with longtube headers,and brenspee tune . It feels fast in 1st and 2nd but after that it feels kind of slow. I was wondering if I would be better going with a pulley swap or gears. I'll be racing it in the 1/8 mile. I'm shooting for 7.5 times
Old 06-21-2016
Get the pulley.
Old 06-23-2016
06TorchRedGT's Avatar
06TorchRedGT 06TorchRedGT is offline
For racing, I'd recommend 3.6" pulley and 3:73 gears.. For street performance 4:10's suck on the highway at cruising speeds above 65MPH, as you end up in higher RPM ranges running all the time..
Saleen series VI S/C - 39lb injectors - 3.6" pulley - Eibach pro kit springs - Borla ATAK mufflers - Pypes cut n clamp X mid-pipe to OEM cats - Firestone Firehawk Indy 500 Tires 275/40/18" square - GT500 strut mounts - Hurst short throw shifter - CFM billet oil cap breather - UPR 4 chamber catch can - Eibach camber bolts - OEM GT500 18x9.5 wheels - Koni adj sport struts/shocks - BMR poly adj panhard bar - Saleen extreme 98mm stock airbox - Autolite HT0 spark plugs - JDM 91 oct performance tune.
Old 06-28-2016
Unless your drag racing with amazing traction adders, stay away from 4:10's. Do you feel a different power curve in 3rd and 4th?
Old 06-30-2016
I have the Saleen hard plastic intake and stock fuel pump. Would I need to change them. With 3.6 pulley
Old 06-30-2016
No you don't.
Old 06-30-2016
No you dont, but its always a good idea to have your air/fuel mixture checked just to make sure your not lean anywhere in the rpm curve. I would consider a drop in single pump (340lph) for some added safety...they are super inexpensive.
Old 07-21-2016
I was alittle confused because one place said the 98 mm Saleen intake is fine and the other place said it won't work. I think I'll go with 3.73 gears then. I was just worried about putting on a 3.6 pulley and running out of fuel because I have longtube headers. I'm going to take it to the track soon with 28 in slicks and see what it does with headers and the 3.8 pulley. Hopefully faster then my Mach1 I just had i went 12.8 with just headers and xpipe. I going for high 11s
Old 07-21-2016
I don't think you'll make it into the 11s with a 3.8" pulley. It all depends on your 60' though. In my old car the best I did with a 3.4 pulley (460 rwhp) was 12.025 @ 116 with a 1.78 60'.
Old 07-21-2016
What rpm did you launch it at
Old 07-21-2016
Cool
Adding lots of rear traction would help!
Old 07-21-2016
I don't remember. It was probably 4 years ago. My current car I cut 1.5x 60s and launch at 5000 rpm on MT ET Street Rs.
Old 07-21-2016
I'm going to use Hoosier 28 inch slick even though it's probably to tall for 3.31 gears.
Old 07-21-2016
I've been running the Saleen 98mm intake with 3.6 pulley, stock fuel pump and 4:10 gears for over 2 years.. Haven't ran into any issues whatsoever, however I would definitely take Jason's advice by having your air/fuel checked just to make certain that your air/fuel mixture is safe..
