Old 04-20-2016
Dpredflag Dpredflag is offline
Default Help: Failed emissions, Long tube headers
I just got a mostly stock 08 Saleen redflag with American racing long tubes and xpipe. I got it in PA and I live in NY . I drove it like 800 miles and went to inspect it and all the monitors where turned off and I failed inspection. Then the other day I got a p0153 and p0133 code. I know it's probably from the 02 sensors not heating up quick enough. Is there anything I can do to fix this. It drives fine to.
Old 04-20-2016
Saleen520's Avatar
Saleen520 Saleen520 is offline
Mine trips the P0153 if I don't let it warm up. I clear the code and its fine
Old 04-21-2016
06TorchRedGT's Avatar
06TorchRedGT 06TorchRedGT is offline
If your rear 02 sensors/monitors are turned off, you will fail the OBDII emissions test and encounter a failure code stating catalyst not ready..
Therefore if the rear 02's are still turned off, you will need to have your tuner e-mail you a revised tune with the 02 sensors being turned on..
Saleen series VI S/C - 39lb injectors - 3.6" pulley - Eibach pro kit springs - Borla ATAK mufflers - Pypes cut n clamp X mid-pipe to OEM cats - Firestone Firehawk Indy 500 Tires 275/40/18" square - GT500 strut mounts - Hurst short throw shifter - CFM billet oil cap breather - UPR 4 chamber catch can - Eibach camber bolts - OEM GT500 18x9.5 wheels - Koni adj sport struts/shocks - BMR poly adj panhard bar - Saleen extreme 98mm stock airbox - Autolite HT0 spark plugs - JDM 91 oct performance tune.
