Q: Rear trunk extention sag?
My rear panel above the left tail light is sagging. At this time it is about 1/2" lower than the wing on the trunk. The right side is lower than trunk wing but not by much.
If I press hard enough it will move into position then return after I let it go. I have not tried to fix this and was going to just let it be but it seems a lot of people notice it and explaining " that's just how it is" is getting old.. Any suggestions? |
Is the tail lamp panel sagging (black)? Or is the trunk extension sagging (body color)?
Trunk extension.
Is the lower part of the extension drooping (like the plastic aged) or does it appear the entire extension can use an adjustment?
I talked to saleen yesterday. They said it may just need re-adjusted.
