CorTex torque arm install
Well, on my continuing quest to improve my Saleen I was researching suspension and brakes when I was reminded of the torque arm. Seems like I always get help finding more stuff to buy and try, in this case it was Jason from 281 Motorsports. I was completing what is intended to be the final state of the motor, and was looking for some replacement suspension. This became more definite after a Saleen tech I spoke to confirmed the Saleen shocks/struts were designed for ~50,000 mile service life and I am well past that at 72,xxx miles. So I call Jason for a shock/strut question and end up talking about the CorTex torque arm. It seems I NEED this part. That kind of revelation usually leads to research, as it did in this case. In point of fact, I could not find any negative reviews regarding this piece. The only real negativity I found online was arguments on manufacturers, there are 2 main camps it seems for the S197 body torque arm, and typical drama follows. Cutting through all that mess, the torque arm seemed highly regarded as a serious upgrade. I talked to Jason and he asked me to write an honest review in exchange for a small discount, to which I agreed. I asked Jason to see if CorTex would coat my torque arm in the Saleen matching red powder coating. Well apparently I am an oddball, but they agreed to make a special run for me at a small additional fee. Color match is spot on! Here goes the review...
On to the install…pretty dang straightforward, but be warned and follow the instructions entirely! Trying to skip steps leads to frustration and foul language, at least it did for me. The steps are clear and necessary, even when I thought, I can work around that. Now, as this piece had been in the garage since early December waiting on me to get the other parts installed and tested so I could accurately describe the effects of each (even if just for my own edification), I had waited long enough and decided to tackle the project in the garage. It was accomplished, after an entire day on my back. In fact, I had to do the LCA adjustment necessary to properly position the suspension/axle after the install, the following day simply because my arms and shoulders had quit on me. So install done…in about 10 hours! This would have been 6 hours on a lift I think. That is one man, and I will tell you that two or three guys with a lift make some things SOOOO much easier. Issues…I got her on the wheels and went for a spin. An ungodly noise/vibration was emanating from the e-brake handle! I parked her back in the garage and waited for morning to try and figure the issue out with CorTex help. The guys there were great, and suggested sending some photos to verify I had not done something horribly wrong, I shot a bunch of pics, checked torque and verified all was installed correctly. Trent at CorTex suggested it might be the pinion bearing failing as all the noise from the rear is now going straight to the forward mounting point of the torque arm. That happens to be directly below the e-brake handle. So I called friend and fellow Saleen owner Cliff Parsons, who owns Parsons Performance Differentials in Beaumont, TX, and scheduled the time to put the rest of my garage stored parts in the car the following weekend. Sure enough, both the front and rear pinion bearings were shot. Everything else was fine, but as planned I had the entire rear rebuilt at the same time with new gears and a Detroit Trutrac diff. The ride home was so quiet I thought I was in a different car. No noise from the torque arm whatsoever! I did discover that the slight forward adjustment of the rear axle that was required was enough to create a slight tire rub at full compression (315 35r20 NT05). Just something to be aware of as LCA adjustments are made. My new coil overs were set at half soft, and needed to be set a bit stiffer in the rear. Thoughts…with quiet comes speed! I enjoyed the ride home immensely. The car now stays remarkably flat not just during acceleration, but also during braking. That is a big plus as the tires and brakes get a chance to really bite! I won’t say I can’t break the rear loose, but it is much more fluid and controlled. Corner throttle goes almost unnoticed, and that is a good thing. During a decreasing radius elevation dropping high speed sweeper I found myself at an uncomfortable speed, even though the car felt flat and controlled. Honestly it was just faster. Personally, faster is always better and I enjoy my car being more capable than I am as a driver so I can grow (and it will forgive me a bit along the way). This change from the upper third link (UCA) to the torque arm is something anyone pushing their car will enjoy, and is just another example of a manufacturing compromise that can be remedied. If you are just a cruiser/car show person, this is not a part that will do you much good, but for anybody pushing higher RWHP, this is a way to put that power to the ground more predictably, and I think speed freaks will love it!
Awesome writeup! I have a new cortex torque arm on its way. Also bought it from 281 Motorsports. Can't wait to feel the difference.
Michael,
First and foremost, thank you for the absolutely clear and concise review. I think you couldnt have told the story better. The feeling and confidence a CorteX Torque arm give the driver is hard to explain. I appreciate your time and all your efforts putting this together!
Awesome Michael! Thanks for the write-up.
2008 302 Heritage 08-0029 |
Somethings I forgot tomention:
The Upper Control Arm (UCA) and mount are entirely eliminated as apparent in the last pic. The LCA adjustment is necessary to align the rear spring perches as the pinion angle is now static and set by the torque arm. With a UCA installed, the pinion angle is set at around -2 deg to compensate for the axle twist that occurs under acceleration. This is no longer necessary as the torque arm prevents the wrap, but that changes the angle of the spring perch slightly, and for some setups, can be enough to make noises/misalignment. My adjustments ended up being very slight, as I ended up almost where I started, and may have been able to eliminate this entirely. Just depends on what changes you have already made. Pinion angle can be changed from what the torque arm sets by shimming the mounting point at the third member ears. I did not find this necessary. I did end up putting a 3" long piece of 3/8' fuel line (split down the length) around the e-brake cable where it passed through the front bracket to further isolate the cable as the hard coating on the cable was grabbing the endge of the bracket. Thanks to Cliff for having some handy!
Michael '07-0449 S281 SC Coupe - 1 of 1 as optioned Last edited by Meikol02; 02-05-2015 at 09:54 AM. |
Did you have to modify the Dynatech X pipe or stock mid-pipes exhaust at all?
http://i1218.photobucket.com/albums/...64581_n2-1.jpg |
The first picture (grey suspension) we had to tweak the pass side and Johns car (blue suspension) we had no clearance issues...
I did not have to modify the exhaust at all.
Awesome job. Install looks great. Is a Watts link required to use the torque arm? Is it part of the kit, or do you need to purchase separately? Will it work with a convertible?
06-115 / S281 3V / SuperShaker / AirLift / Zenetti Baron forged / JDM / 3M Liquid Copper Wrap |
A Watts link is not required to install a Torque arm....but is where I would start. The two pieces are sold separately. Yes, it will work with a convertable.
Thanks for the feedback Jason and Meikol02.
Meikol. Is there a spec that you are supposed to set the pinion angle to or is it just based on misalignment of the springs? I have rear coil overs where the spring is on the shock so I do not see how this would effect my setup.
Anybody know the answer to my question?
I did not see your post, sorry. My "coil-over" set uses an adjustable spring perch in the rear (the same as the Saleen/Pedders kit). The adjustment of LCA's for spring alignment would not apply to you. The Pinion angle is set by the torque arm.
SidVicious, I had the CorTex Watts link for the last 2 years and just added the torque arm as an upgrade.
I did discover that I had "over adjusted" the LCA's and was able to move the axle back a bit which eliminated the audible rub at full compression, wihtout causing any issues.
Just got my torque arm installed last night. Only gear noise is very slight at 60mph, but otherwise silent. Can't comment on performance just yet...
Launch on it Josh!
Nice write up buddy! I didn't realize that the UCA would be eliminated with the torque arm.
Thanks for the write up, I have been looking at the torque arm and watts link since last fall. Hopefully this will be my summer project.
Let us know if you choose and we can get a package together for you.
I thought the hardest part of the install was removing that dang upper control arm mount. Gotta drop the fuel tank a little to get it out...
Ford changed that on the 2011+. You can now just remove the bracket and the gas tank flange is no longer in the way....makes it awesome!
the wattslink and torque arm is usually one of the first suspension mods I suggest, it works great and the fitment is almost spot on.
The good thing is that it's great for street cars as well and not only for roadracing. Hennie |
cortex sn95 fox watts/torque arm
Jason @281 motorsports-
A while back I noticed cortex makes a watts/torque arm setup for a fox or sn95 setup but couldn't find anyone online that is running the setup or any pics installed...Have you guys done a install on a foxbody? or seen it installed on a fox or sn95,any thoughts...
Saleen Alcons,Dart Block 347,G Force T-5,Vortech T-trim,Glenns performance fuel system,Snow performance stage 3 methanol kit Etc... |
Jason
If you add the cortex torque arm and watts link to a 2007 S281E car what has to be changed? do you have a package? |
Give me a ring on monday and ill walk you through everything you need to know.
Michael did you install the watts link your self?
I am having a hard time with everything I got from Cortex but the instruction for adjusting the watts link don't exist. any pointers would be great |
Steve, It sounded like you got all the info you need from our tech today, are you all set?
