Old 05-20-2015
06SaleenExtreme's Avatar
06SaleenExtreme 06SaleenExtreme is offline
Exclamation Q: Defective Air Bags, what is the repair?
There was a news story on this morning stating cars made from 2000-2011
could have defective air bags, that have already been fatal. The news stated
1 in 7 cars could have this air bag. They also mentioned all the major manufactures may have these bags. So far 43 million autos are estimated.
http://www.latimes.com/business/auto...519-story.html
Old 05-20-2015
SimiSaleen SimiSaleen is offline
Wow huge amount of cars. Looks like my 2000 Saleen could be at risk.
Thanks Wyatt
Old 05-20-2015
gliioct14's Avatar
gliioct14 gliioct14 is offline
https://vinrcl.safercar.gov/vin/
plug in your vin and see if your car is on the list
Old 05-20-2015
I tried the previous site listed, it did not work for me. I used this site and selected Ford and put in my VIN. My Saleen is part of the recall.
http://www.safercar.gov/rs/takata/index.html
Old 05-20-2015
Meeker1's Avatar
Meeker1 Meeker1 is offline
Default safecar.gov
Site is blocked due to heavy traffice since tonites national news . . redirects to Ford Service Site . . VIN number input indicates my '06 SC vert is recalled for air bag
Old 05-25-2015
tmiles tmiles is offline
My 2006 drivers side is included in the recall. Lucky me.
Tim W. Miles
06-1241 S281SC Scenic Roof
Old 05-25-2015
sidvicious's Avatar
sidvicious sidvicious is offline
Mine too. Waiting to hear from Ford dealer. Could be a long wait.
06-115 / S281 3V / SuperShaker / AirLift / Zenetti Baron forged / JDM / 3M Liquid Copper Wrap
Old 05-25-2015
So... what parts are actually replaced during this service?
Old 05-26-2015
RedFire281 RedFire281 is offline
Will it require a PCM re-flash? Or just the airbag module like they did on the passenger side airbag TSB?
Old 05-26-2015
gliioct14's Avatar
a re-flash is required be careful if you have any tune it will be gone and reverted back to a stock config
Old 08-03-2015
EXTREME302's Avatar
EXTREME302 EXTREME302 is offline
Looks like the E car will be visiting Ford soon.....
2009 S302E #02
Old 08-03-2015
Got my notice last week. I'm trying to wrap my head around how that will work if they have to re flash the PCM?
Old 08-03-2015
06silverS281 06silverS281 is offline
godda****. just got my letter in the mail today from ford and just had my car tuned recently
Old 08-04-2015
Firehead's Avatar
Firehead Firehead is offline
Got my letter too. So, I'm guessing I take the car to the dealer. They "correct" the problem and flash the PCM, then the car doesn't run so then I'll have to pay them, and Saleen, to remove it again and send to Saleen for a re-flash. Un-freaking-believable.
Old 08-04-2015
There is conflicting information out there. Last I heard, the air bag recall does not require a PCM reflash.
Old 08-04-2015
gliioct14's Avatar
Dave
You be the gunnie pig for the forum - take your pj for the recall and tell us what happens - thanks in advance
Old 08-04-2015
I have no plan to have the recall work completed.
With that said, there will be a second notice when recall parts are available and we are actively seeking detailed repair instructions.
Old 08-04-2015
It's going to be a while before the fix is available.
Old 07-23-2016
Jimbo170412 Jimbo170412 is offline
Default airbag recall, anyone know the details?
I have an airbag recall question (15S21). This is for a 2006 SC with a JDM tune and an aftermarket driver seat.
Will getting the airbag/actuator replaced require putting the tune back to the stock saleen tune? Do they mess with the ECM?
Will it require re-installing the stock seat.
Hoping they just drop in the new parts and call it done.
Will find out from dealer on Monday, but just in case somebody knows....
Thanks.
Old 07-23-2016
Please post what the dealer does.
Thx
Old 07-24-2016
OneQwkStang's Avatar
I had both my 2006 and 2011 recall repaired. The dealer replaces the inflator and that is all, the entire job takes less than 30 minutes.
Old 07-24-2016
Good to know thanks.
Old 07-25-2016
2007-52 2007-52 is offline
I watched the dealer replace mine... No PCM re-flash required. It's a VERY simple procedure... Remove (2l 10mm bolts on the sides of the steering wheel... The entire inflator assembly slides out... Unplug the electrical cable. Then four small screws hold the inflator in place. Reverse process to install. It should take about 5 minutes.
Old 07-25-2016
Thanks for the post.
Old 08-08-2016
Meeker1's Avatar
Default Driver Airbag recall 06-1264
Finally made some time to have the new airbag installed . . as mentioned in earlier post, simple procedure . . hats off to my dealer Metropolitan Ford Mpls. Master tech at the shop took special care when turning over existing bag with Saleen emblem on reverse side . . placed on numerous shop rags as to not scratch the emblem and carefully installed new bag with care . . install took only a few minutes but paper work to Ford took additonal 25 minutes . .
Old 10-25-2016
kss113's Avatar
kss113 kss113 is offline
Default Have not done mine yet
I was told by Ford that both drivers side and passanger side airbags had to be replaced, and that only the drivers side is currently avaliable.
So I'll wait till they both are avaliable then make one trip to the dealer.
07-55 SC Speedster;
1 of 1. Even with the mode that follow it's still 1 of 1.
3.4 Pulley, Saleen Extream CAI, VI.5 Lid ported, Tune, 62mm FR Throttle Body, Upgrade Chrome 5 spoke wheels, Max Diff 3.73 gear, Rockford punch, Rear bumper inlays (black chrome), Speedster, HID Lights, Saleen Duel Fuel Pumps, MoSaleen Idler, blackout side markers.
1968 GT Convertible Diamond Blue C-Code Concourse. Sold
00-372 - Triple black Conv. Soft Speedster cover. - sold
