Old 06-20-2015
tnsaleen tnsaleen is offline
Default Q: Seat foam replacement?
Does anyone know where to get replacement seat foam for my 05? I am under the impression that it is different than a GT because the side bolsters protrude more.
I was also thinking about trying the TMI seat foam, but would rather find the foam that was used.
Old 06-20-2015
07S281SC111's Avatar
07S281SC111 07S281SC111 is offline
Also interested in this. My drivers seat top cusion bolster and lower cusion bolster(closest to the door) are both a little disfigured from the previous owner.
Old 06-20-2015
Sent their customer service an email. I will update with what I hear back. Thank you.
Old 06-22-2015
Will you please let me know what they say when you get a reply? I am having the same issues as you.
Old 07-08-2015
Never received any kind of feedback from them. Not sure which other avenues to take.
Old 07-08-2015
We will send a note.
Old 07-18-2015
Any luck in hearing back from them?
Old 08-11-2015
Saleen Automotive is working on something relevant to this need.
Announcement to come. Stay tuned.
Old 10-08-2015
jeff beaudry jeff beaudry is offline
Default seat foam and covers
seen this add in Edmonton Alberta Canada
http://www.kijiji.ca/v-other-auto-pa...ationFlag=true
he also has a carbon front lip splitter and rear carbon fiber reat defuzer. Tell him Jeff forward his add to you guys in need.
Old 10-08-2015
Bargain price.
Old 10-09-2015
Firehead's Avatar
Firehead Firehead is offline
Seriously. I wish I had the cash to pick these up. Worth every penny and then some.
Old 01-05-2016
Any update on the seat foam coming out? I just noticed I too suffer from the yellowish "snow" under/next to my drivers seat.
Old 01-05-2016
sidvicious's Avatar
sidvicious sidvicious is offline
I've also been dealing with this problem in my 06
06-115 / S281 3V / SuperShaker / AirLift / Zenetti Baron forged / JDM / 3M Liquid Copper Wrap
Old 04-23-2016
Any update?
Old 05-27-2016
Any update on this?
Old 09-20-2016
465stroker 465stroker is offline
Default Info on Saleen Seat Foam
I saw a thread a while back but cannot find it now. The thread was in regards to what seat foam Saleen uses for there seat covers. Many people have issue with the seat and side supports nearest the drivers door breaks down over time and does not support as well << I have the same issue on a 66K mile cart I just purchased.
Answer is - they use stock seat foam then add / glue additional foam as needed to fill out the seat side supports. I will be taking my car to an upholstery shop to get the drivers seat fixed and door panel material re-glued as it is also starting to de-laminate.
Old 09-20-2016
Actually they didn't use the stock foam, it was all replaced. I contacted the company that made the foam for Saleen & was told they no longer produce it.
Old 09-20-2016
Well my car is scheduled for next Tuesday to get the seat padding repaired. I will report back what they find under the cover. The shop will be fixing the upper & lower drivers seat side cushions (leather is in good condition yet) and also drivers & passenger door panel material that is separating for $375.00
Old 09-28-2016
Barricade's Avatar
I have dabbled in the Saleen leather upgrade on the stock frame and tbar is 100% correct. Its a whole diff foam animal under that leather.
I would wage any good upholstery shop can remove, inspect, then cut and glue in the correct (cut to size) dense foam piece.
-ǝsınƃsıp uı ʇoqoɹ-
BARRICADE 643
06-108E
Old 09-28-2016
I just picked up my car from upholstery shop to get drivers seat foam repaired (door side seat and back side / lumbar was squished). I also had both driver and passenger door panel material replaced that was falling off. Previous owner was really big guy.
This company does a ton of mustangs and they said the foam looked like factory with additional "stitch foam" added to the leather covers. They found the stitch foam deteriorated and seat foam split.
