Old 06-27-2018
Robert Failla's Avatar
Robert Failla Robert Failla is offline
Default Help: Saleen HID Headlights
Hi. My headlights/ hibeams have recently gone out. I bought the car without an owners manual. Can someone please provide information on the correct relays/ fuses, etc. to check? Thank You.
Robert
Old 06-28-2018
2007-52 2007-52 is offline
I think the high beams have nothing to do with the HID lights themselves, and should be on the normal Ford circuitry. Attached is the installation guide fir the HID lights. I don't know if it contains what you need or not. If you need the factory fuse location / number I can get it for you as well. http://cloud.tapatalk.com/s/5b348507...02-C11870C.pdf
Sent from my SM-G965U using Tapatalk
Old 06-28-2018
There are two relays located by the fuse box. Start there.
Old 06-28-2018
There are also two fuses attached to the passenger side shock tower... Instructions should show you where all that stuff is supposed to be mounted.
Old 09-09-2018
mosaleen's Avatar
mosaleen mosaleen is offline
Robert did you figure out your Hi, beams not coming on... my 05 Saleen Hi beams just stopped working last week... will not come on at all.
Scott
3:73 gears, Watts link Gen II
