Old 08-02-2016
jay07 jay07 is offline
Default Help: SuperShaker, loss of Power/Hesitation when cold
Hey guys. I'm hoping someone can help me with an issue with my 2007 Saleen Supershaker set up.
My car has a really bad hesitation/loss of power issue that occurs when the car is first warming up. The car starts great and everything seems great and it even drives well for the first minute or so, and then it starts hesitating badly until the engine warms up for another 3-4 minutes and everything seems fine. Note that if I shut the car off and go to drive it again within a few hours, there are no problems what so ever. This only happens when the motor cools down completely. I'm guessing it has issues when it switches to closed loop and the engine is cold.
Fuel pressure looks good and is up around 40psi all the time.
I have replaced both upstream oxygen sensors (I was getting a O2 slow to respond about once a year and thought it might fix it, it didn't).
The vacuum gauge seems to indicate that the throttle body is opening up when I press the throttle and everything is cold when the hesitation occurs. Vacuum moves towards zero when I press the throttle.
Spark plugs were replaced last year with the same type of colder plugs that were in before.
MAF has been cleaned and did not help. Coolant temperature as shown by the OBD-II data looks reasonable, although Intake Air Temp shows hotter than I'd expect when the car has been sitting all day (i.e. 90 deg outside, coolant shows 88 deg, IAT shows 105).
Any ideas?
Old 08-02-2016
06SaleenExtreme's Avatar
06SaleenExtreme 06SaleenExtreme is offline
Is your car running the stock tune?
Old 08-02-2016
No, it is running a 93 octane tune for a 3.6 pulley. I have a 91 octane tune I could also try just to see, but it is also not the stock Saleen tune due to the use of a 3.6 pulley instead of stock 4.0.
Old 08-02-2016
My 2 cents thinks it is your tune. What your describing, is exactly what occurred to me when I first got my Saleen. I took it to a tuner in Long Beach and picked up the car when the engine was warm and there were zero issues. When I took the car out the following week, the car would cut out unless I fully let it warm up. I found another tuner who corrected the issue.
Old 08-03-2016
I haven't had this problem until recently and I've been running this same tune for years. Although I have to admit the hesitation is getting worse.
I've started to try datalogging to see if I can spot anything, but I must admit that I'm not sure what exactly I am looking at in the data. Does anyone know of any online guides that gives hints as to what I'm looking at in the data from my SCT X3 and what it means?
Old 08-12-2016
For anyone else who runs into this, I was told that on these cars with the Saleen supercharger that hesitation can be caused by either spark plugs, dirty throttle body, or problems with the bypass actuator.
Spark plugs are not even a year old, so they are good. The bypass actuator seems to be working correctly when I test it manually. So I took everything off so I could remove the throttle body and cleaned it really well. The car runs much better now, although it still does hesitate a little bit. Next time I may try to take the intake plate off and just get in there and clean whatever I can reach.
I hope this helps someone else!
Old 11-22-2016
Geiger89 Geiger89 is offline
Did you get any resolution on this. Mine does exactally what you describe. I have cams that are going in thursday and vmp doing the tune so hopefully that issue will be resolved in the tune. Just wondering if you found another culprit.
Old 11-22-2016
Nope, just cleaning the throttle body very thoroughly. Here is a video with some explanation:
https://www.youtube.com/watch?v=Cxf9mQZ7nDE
Old 11-22-2016
Maybe catch cans are next.
Old 11-22-2016
I do have a catch can. It's amazing how fast it fills up.
Old 11-22-2016
Have you noticed any long term advantages with the tb staying clean?
Old 11-22-2016
With the catch can? Nope, not regarding keeping the throttle body clean.
The catch can catches oil vapor before it goes into the intake manifold, but it goes in after the throttle body (driver's side). So it has nothing to do with that.
The passenger side goes into the intake before the throttle body but I'm not really aware of anyone putting a catch can on it. I'm not sure that would help.
