Old 11-26-2016
FlashRobert FlashRobert is offline
Default Q: Saleen front sway bar mount? - 2007 S281 SC
So, looks like the bracket from the front anti sway bar to chassis, core support ? Has snapped off completely ....
can anyone tell me if this bracket is standard ford bracket with wider bushes for the Saleen anti sway bar (apparently the sway bar is bigger than standard ???? ) or if it is a specialist part for the saleen ?
I see lmr have both the bracket kit and bushes for 28 and 34 mm. Does this look like it will suit?
I have yet to pull it off and have a close look .... was hooping for some info before doing so
Old 11-26-2016
Default Images of the offending item
Left and right anti-sway brackets (front) and bushes ... 34 mm sway bar .... one of these brackets has clearly sheared off .... interestingly there is oxidation on the break so not a totally new break ... it just finally ??? gave way on a corner today.
Old 11-26-2016
Firehead's Avatar
Firehead Firehead is offline
Looks like Energy Suspension to me.
Sent from my XT1585 using Tapatalk
Old 11-26-2016
I grease and inspect these mounts once a year. (Usually in the springtime.)
Per recommendation in the Saleen Owner's Supplement manual.
Heavy duty Steeda mounts
http://www.steeda.com/
Old 11-27-2016
Thanks Dave .... they look like they will do the trick
Old 11-28-2016
jrcalvin jrcalvin is offline
Default Saleen sway bar bracket
My stock Saleen sway bar bracket on the left broke at the track. The broken sway bar bracket allowed the front sway bar to move rearward and it punctured the oil filter, creating a huge trail of blue smoke. I then replaced both standard brackets with a FRPP HD brackets.
Tags
antiroll, antisway, s281sc, suspension
