Go Back   The Saleen Forums at soec.org > Saleen Mustang Discussions > 2010-2014 Saleen Mustang
2010-2014 Saleen Mustang For the SN10 platform California-built 2010 SMS 460 and 460X, the 2011-12 SMS 302, and 2013-14 Saleen 4V, SC, SSC and 351.
All Label cars (White Yellow, Black). Be sure to specify year, model and equipment if asking for help.
Old 01-01-2014
Default Q: 2010-12 HID retrofit?
Anyone know who makes these?
I really like them as they keep the 2011 headlight to marker realtionship.
Old 01-01-2014
Barricade's Avatar
Barricade Barricade is offline
raxium did....but I think they only make projectors now.
-ǝsınƃsıp uı ʇoqoɹ-
BARRICADE 643
06-108E
Old 01-01-2014
Are the 2010-12 turn signals on a separate harness from the headlight?
If the standard 2010-12 headlight reflector is the same as the standard 2005-09 reflector... and if the turn signals are independent from the headlight... it may be possible to take the guts from a 2005-09 Saleen HID light and place it in the 2010-12 housing.
Would be a costly and time consuming experiment.
Old 01-01-2014
Coderedsaleen Coderedsaleen is offline
Here, check out these site for Halo types of lights:
http://www.nfcperformance.com/ford-m...alo-headlights
http://www.americanmuscle.com/oracle...sion-1012.html
Old 01-01-2014
Okay, now that you have clarified what this actually is, I really want more what the 2013's have but are arranged in the 2012 confiduration. I'll have to look at the wiring to see if it is seperate.
Old 01-05-2014
Probably would be easiest to retrofit the 2010-12 HID lights or the 2013-14 HID lights.
Looks like the reflector in the standard 2010-12 headlight is missing the top of the circle. IE: The reflector is not a complete circle. The 2005-09 headlight reflector is a circle.
On the SVT Forum someone did retrofit the 2013-14 HID headlight assemblies to a 2012 Boss 302.
Old 01-06-2014
Is there a difference between the 2010-2012 and the 2013-2014 units?
Old 01-07-2014
Yes. Though they are basically the same. The main difference is the 2013-14 assembly features the LED running light over the turn signal.
I may be mistaken, but the front markers/signals are lit with the headlights in 2010-12. In 2013-14 the front markers are the LEDs and the yellow signals are only lit during a turn indicating.
Old 01-07-2014
Here is a 2010-12 non-HID assembly retrofited with a projector lens for HID use.
Old 01-07-2014
Custom 2010-12 retrofits.
Old 01-07-2014
These things are sweet. I would like to keep the amber markers though. I will check out their website. Thanks!
Old 01-07-2014
Looks like some folks remove the amber plastic when the lens in apart.
Someone used a modified version of this harness to run the factory HID lights:
- http://www.theretrofitsource.com/pro...ducts_id=14029
- http://www.allfordmustangs.com/forum...483-post1.html
A retrofit:
- http://www.modularfords.com/threads/...alogen-housing
HID parts:
- https://www.theretrofitsource.com/
