Old 08-05-2017
colin099 colin099 is offline
Default Q: Method to bleed Intercooler? - Series VI
Would I be ok using an airlift tool to bleed the i/c? I recently removed the water crossover to install a s/c dipstick. I've looked at the manual and can't quite figure out how to fill/bleed.
Old 08-05-2017
tbrock's Avatar
tbrock tbrock is offline
Is the intercooler pump is pushing the coolant through the system? If not then burp it at the HE. I would loosen the clamp and pull it loose carefully until I got the air bubble out. I eventually upgraded to a larger HE a 2013 GT 500 intercooler pump and I have my system setup so that the water enters the HE from the bottoms so it will naturally force the air out.
2007 Shelby GT, Saleen SC Stage 3 with 3.0 pulley,mosaleen tensioner sys. UCA,LCA,BMR A arm Brace, SVE Dark Stainless 18x10's, Nitto NT05's, MGW Shifter, Pypes LT's with off-road X pipe, Bassani Axle backs, FRP 3.73's,BMR Watts Link, Steeda shaft loop, JLT 110mm CAI, FRP valve Covers, Brenspeed tuned. 12.425@114.63 4800 feet on Nitto 555's. Latest dyno is 492hp/463tq.
Old 08-06-2017
The i/c pump is running, i can see it cycling water thru. Im guessing just running it with the recovery tank cap off would cycle all of the air out right?
Old 08-06-2017
And if there were air pockets in the i/c system it would just affect iat's right? Is it possible to fry something the same as if there were air pockets in the rwgular cooling system?
Old 08-06-2017
tbrock's Avatar
If you see water moving through the tank there shouldn't be any air in the system. Yes you are correct if you had an air pocket in the system and no water was circulating it would effect the AIT's and it could effect the power of the car = cutting the timing.
