Old 12-10-2012
pine9280 pine9280 is offline
Default Headers install
I found this set of instructions for the set of headers i want to install on my Saleen. They are instructions for 99-04 Cobra and 03-04 Mach1 http://1.cdn.lib.americanmuscle.com/...04-install.pdf How much will these instructions differ for my Saleen or will they be pretty identical?
Thanks guys
Old 12-10-2012
Coderedsaleen Coderedsaleen is offline
You can do it like that but you don't have to remove the K-member for the 2V. Just take off the two engine mount nuts and raise the engine. Unhook the steering knuckle so that it will slide between the tubes of the new header. You might want to take off the starter to give a little bit more room. Atleast this how I installed them on my 2V.
Old 01-02-2013
Was it a pretty big pain in the ***?
Old 01-03-2013
Wireman's Avatar
Wireman Wireman is offline
Here is a write up i did during mine, hope it helps.
http://saleenforums.soec.org/showthr...ight=Long+tube
Last dyno put me at 394 / 405 after the header install and aluminum drive shaft.
03S281SC 03-269
Tunable induction CAI|2.8 pulley|39# Injectors|05 Mustang GT pump|90mm MAF|75MM BBK-TB|Mosaleen idler|MAC Long tube headers|Mac Off road X|LFP-H/E and tank|Chicane I/C|5gpm pump|373 FRPP gears|NT555R 305/35ZR1|MGW shifter|FRPP Alum driveshaft|N2MB two step
86-0087
03-269 S281SC
92 LX coupe
92 LX convertible
Old 01-03-2013
So you just jacked up the front and removed the engine mount bolts and jacked the engine up? Where did you jack the engine up from...oil pan? Also, you mention the starter but what other components did you remove for the install? Lastly, if you were to do it again would you remove the whole k-member?
Thanks for the feedback guys. Nice thread Wireman
Old 01-30-2013
WildWillyWalker WildWillyWalker is offline
Here is my install:
http://www.cjponyparts.com/mustang-a...uctions/a/340/
It's a bit of a pain. It'd be a LOT easier if I had a lift.
Old 01-30-2013
saleensonoma saleensonoma is offline
modulars are a PITA when doing headers. The way codered mentioned it is how i do it. I have an engine lift so its easier for me to do it.
Saleen SC 89-0305
01 Bullitt #3251H/C/Turbo build
92 GMC Typhoon
89 Chevy S10 Cameo
07 Yamaha R1 Candy Red
Old 02-11-2013
99-0179 99-0179 is offline
Just plan on dropping K-Member, Supporting motor w/ a jack and adjusting up/down as necessary to get the headers in...
OH AND!.... don't cheap out on the gasket!
Old 02-12-2013
Jason @ 281m's Avatar
Jason @ 281m Jason @ 281m is offline
Thats sounds scary!!
Jason | 281 Motorsports
NO PM'S - PLEASE CALL | 714-575-1505
1996 Cobra Vortech SC / Track prepped
2015 Coyote Powered F-150
Check out our facility promo video here: http://bit.ly/1yHNfxM
Email: 281motorsports@gmail.com
Web: www.ProSpeedMustang.com
Facebook: www.facebook.com/mustangperformance
Youtube: http://bit.ly/1zOxanf
"Doing the job right...is the ONLY option we offer!"
Old 02-12-2013
Supporting a motor on a jack can be dangerous, not to mention if you have a slip. what it could do to the motor. I had to do that once to replace an oil pump on the side of the road... I wouldn't suggest it.
Old 02-12-2013
Either way you do it you have to jack up the motor. Unless you get an engine lift. What is the best place to jack it up anyway?
Old 02-15-2013
Ok what I DID which isn't the safest method, but I like to rely on my intellect when it comes to dangerous maneuvers.
Make sure you have a decent jack first off. I placed the jack straight in from the front of the car and supported the motor with a wooden block right under the harmonic balancer. Make sure you have the belt off. I was able to get all the up and down movement I needed.
Another safe measure would be to use jackstands as a backup placed on both sides of the oil pan in case it DID fall, you wouldnt be hammering the dents out of the oil pan.
