Old 12-04-2015
pj#472 pj#472 is offline
Default Help: Video on Camber Bolt Install?
How's it going all?
Anyone know of any videos on installing the Ford Camber/Castor bolt kit (4R3Z-3B236-AB)? I have the general knowledge of knowing that I have to grind out the bottom strut hole just a tad (as prescribed by dealership) and it's pretty straight forward......but would still like to put eyes on someone doing it.
Thanks!
Old 01-07-2016
jrcalvin jrcalvin is offline
Default camber bolts for PJ
I am not sure it the Ford camber kit uses the same stock diameter 14mm strut bolts. It they do, all is good. Most camber bolts have only a 12mm eccentric bolt and that is a little scary load wise.
If you want more or less camber, install good quality camber plates.
Old 01-28-2016
hfnav hfnav is offline
I just used 'Ford Camber/Castor bolt kit' in Google and it found a Ranger install which might be enough of the idea for you. I will warn it may be disinformation but I was curious on your post and desired a quick education and I am content. Good luck.
Old 01-31-2016
Install all done....super easy. Just followed the Ford recommended method using the camber/castor bolt kit. Had to notch the bottom strut hole about an 1/8th of an inch, install the bolt, get an alignment and torqued to factory specs. Fun and easy.
