Old 12-19-2015
NJSALEEN NJSALEEN is offline
Default Q: Stern 17" Center Bore Diameter?
Q: Purchased a set of 17" Stern 3 piece wheels with 66.1 hub bore.
What is the correct size I need to have these centers machined to fit a Fox Saleen? Is it 70.0 exact?
I am just too lazy to remove the front wheel to measure the front rotor hub.
Please send help.
87#178 Grey Hatch
87#219 Black Hatch
88#09 Ranger Sportruck Blue (1of1)
89#579 RACEPAINT Hatch (1of4)
89#25 SSC (Official/unnoficial 25th anniv.)
90#194 Red Hatch (Stuck in Europe W/4k)
96#125 S281 Tangerine Speedster (1of2)
98#02 XP8 White AWD
Old 12-19-2015
This thread my help:
http://saleenforums.soec.org/showthread.php?t=18478
Old 12-19-2015
Dagenham Dagenham is offline
I have asset of stock rotors laying around. If I remember, I'll measure the hub size for you.
Oxford white
Blue stripes
Tan interior
Old 12-19-2015
I put '03-'04 Mach 1 wheels on my stock svo rotors and the centers wereto small on the wheels by thousandths of an inch. I removed the rotor and the studs from the rotor and used a soft disc grinder around the rotor hub and basically shaved A very minimal amount off to make them fit right.
You may be able to do the same thing.
Oxford white
Blue stripes
Tan interior
Old 12-21-2015
I measured a stock '91 5.0 rotor at 63mm.
Hope this helps.
Oxford white
Blue stripes
Tan interior
Old 12-24-2015
SA10#04 SA10#04 is offline
Hope this helps.
The 4 lug rotor has a smaller snout. The 5 lug rotor has a larger hub. It's just shy of 70mm. 69.6 I believe. Quoting from memory there though. Most Ford OE wheels are 70.3-70.6mm hub bore. I've bored out the Stern's to 73mm so that there are no issues. Most of the Stern's I've owned with the hub's the correct size from Hinodex (Stern's parent company) were 72-73mm.
SA10 #4 Chassis
www.puristmotorsports.com
Old 12-24-2015
87 vert's Avatar
87 vert 87 vert is offline
The guru has spoken. I would take the previous posters word s gospel. I have bought and sold and still own a few sets of sterns. Never without talking with him first. Merry Christmas Bob and all!
Old 12-27-2015
Appreciate the info.
Thanks to all for the input.
Opening hubs to 73.
87#178 Grey Hatch
87#219 Black Hatch
98#02 XP8 White AWD
Old 04-14-2017
OxfordS281's Avatar
Will a 77mm hub bore work on the 87-93 Saleen?
2002 #48 Mineral Gray Extreme
Old 07-06-2019
calbear calbear is offline
Sorry, I put my reply in the wrong thread.
____________
Anyone know of a 25 mm hub centric wheel spacer for front 87 Saleen. All the ones for 94-14 that say should fit- do not (HRE Trak plus, American muscle generic billet ones). I was directed to Maximum Motorsports, but in the descriptions- it states specifically does not fit SVO/Lincoln fronts.
The center hub won't allow the spacer to sit flush against the rotor face/hub. [I have stock Brembo Lincoln/SVO replacement- not sure that could be the reason?]
I found some generic T6 ones on Ebay for Lincoln Mark VII and it seems that the hub opening is just a tad bigger, but since I wanted to see if there were any known options.
Mahalo in advance.
87-0116 owner
former Saleen Autosport Anaheim Hills employee
89 Saleen Mustang and SSC production line
Specialist: body work assembly, decals, detailing
Old 07-17-2019
Finally found one that worked and clears the Mark VII/SVO large snout hub without modifications. The key is that the center bore not have an inner lip. If the center hub is smooth like this one, if will clear. https://www.amazon.com/UberTechnic-H.../dp/B00KTPE9S0
87-0116 owner
