Old 08-18-2017
Jay2006-S281E's Avatar
Jay2006-S281E Jay2006-S281E is offline
Default Q: Cold air intake?
I need to fabricate or purchase a different set up than my current CAI. This does nothing if you ask me. Having a little shield blocking the filter from the engine 20 inches away is pointless. That area is just as hot as any other spot under the hood. It's a big deal I need to tackle being in the hot Phoenix area.
Old 08-18-2017
Pretty much every other kit is the same configuration to what you have. The Saleen Extreme kit CAI is the only one I know of with a totally enclosed filter. A bigger fanned heat exchanger and possibly a new pump will help a little in lowering your intake air temps.
Old 08-18-2017
The Saleen Ultimate Air Intake. Standard on the 2008-09 S302 Extreme.
Old 08-19-2017
gamon302 gamon302 is offline
Default Air intake tube
Will do thanks for the info.Not sure but a friend who used to work for Saleen for a number of years is pretty sure he has found me the air intake tube. Thanks for the help.
Greg
Old 08-19-2017
Cool! BTW: I believe the guys at JDM Engineering once said the stock Saleen Extreme intake system flowed well enough for most applications.
Old 08-21-2017
Yea for months I've been looking online for that box off the Saleen Ultimate Air Intake setup with no luck. On another note, the simple fact that the stock intake air filter has a good housing and enclosed top is good. I might pick one up, do some cutting and modifications to the bottom and use it. Route some air flow to come up from the bottom when moving.
Old 11-08-2017
06TorchRedGT's Avatar
06TorchRedGT 06TorchRedGT is offline
Exactly my reason for staying with the stock 07-08 Extreme intake w/hard plastic inlet tube..
Saleen series VI S/C - 39lb injectors - 3.6" pulley - Eibach pro kit springs - Borla ATAK mufflers - Pypes cut n clamp X mid-pipe to OEM cats - Firestone Firehawk Indy 500 Tires 275/40/18" square - GT500 strut mounts - Hurst short throw shifter - CFM billet oil cap breather - UPR 4 chamber catch can - Eibach camber bolts - OEM GT500 18x9.5 wheels - Koni adj sport struts/shocks - BMR poly adj panhard bar - Saleen extreme 98mm stock airbox - Autolite HT0 spark plugs - JDM 91 oct performance tune.
