Old 06-22-2011
Default What the inside of a Series VI looks like with no fluid!
Hey Guys,
We've been getting a ton of calls about this, so I thought I would post up some pictures and explainations. What you guys need to do to conduct a self check is, look at the snout and the base. If the base has blue sealant like this one did, you can almost guarantee its leaking. But if it has red sealant, its a better chance its not. But the snout or the casing will look damp or wet. The biggest misconception is that you will see oil if its leaking - that is not the case. After servicing as many of these superchargers as we have, we now recommend having these looked at if your car is exceeding 40k+ miles on the supercharger.
If you need / want your supercharger serviced, our services include:
Remove Supercharger (or you can ship it to us)
Disassemble Supercharger Rotating Assembly
Repack Rear Needle Bearings
Clean and re-coat supercharger screw journals
Inspect Screws, gears, & gear casing
Remove and inspect/clean the internal heat exchanger for leaks
Reassemble Supercharger and fill with new gear oil.
Inspect (replace if needed) boost bypass valve (new addition to our service)
Install New Spark Plugs
What happens when your supercharger runs out of oil (notice the blue sealant):
To make the forged pulley change colors like that requires some extreme heat!
New Screw drive assembly:
New drive assembly with a new coupler:
Old 06-22-2011
This is what your internal heat exchanger looks like:
Pressed in needle bearings that use a Rheotemp grease that apparently could cause kidney failure if it gets on your skin.
Old 06-22-2011
ExtrmStang#67's Avatar
ExtrmStang#67 ExtrmStang#67 is offline
Thank you Jason. Seeing and reading about this stuff is priceless.
Old 06-22-2011
My pleasure Erik!
Old 06-22-2011
EXTREME302's Avatar
EXTREME302 EXTREME302 is offline
Wow! This makes me want to check my supercharger daily! Thanks for the post.
2009 S302E #02
Old 06-22-2011
LOL, a visual inspection at your 3k oil change is fine. The unique thing about the Superchargers is they dont consume or burn the oil, so as long as its not leaking, your 40-50k service on the blower is fine. If you have a Speedlab Center near you, have them give it a looksy once a year.
Old 06-23-2011
ExtrmStang#04's Avatar
ExtrmStang#04 ExtrmStang#04 is offline
Great Post Jason, thanks
Old 06-23-2011
kss113's Avatar
kss113 kss113 is offline
Wow great post. The screws are like art work..
07-55 SC Speedster;
1 of 1. Even with the mode that follow it's still 1 of 1.
3.4 Pulley, Saleen Extream CAI, VI.5 Lid ported, Tune, 62mm FR Throttle Body, Upgrade Chrome 5 spoke wheels, Max Diff 3.73 gear, Rockford punch, Rear bumper inlays (black chrome), Speedster, HID Lights, Saleen Duel Fuel Pumps, MoSaleen Idler, blackout side markers.
1968 GT Convertible Diamond Blue C-Code Concourse. Sold
00-372 - Triple black Conv. Soft Speedster cover. - sold
Old 06-23-2011
WickedS281SC's Avatar
WickedS281SC WickedS281SC is offline
Thanks for the info Jason !!
Old 06-23-2011
06-0259SC's Avatar
06-0259SC 06-0259SC is offline
Those pictures look familiar. Jason and everyone at 281 did a fantastic job rebuilding my disaster.
Old 06-23-2011
Char259 Char259 is offline
How many miles did your disaster have on it, curious?
[SIGPIC][/SIGPIC]
13 Boss Laguna Seca #738
05 s281 #1401~ Sold
Old 06-23-2011
06-0259SC's Avatar
5,000 miles
Old 06-24-2011
Matt was kind enough to let us keep the carnage...so if your in the area stop by and take a look at it. We put it in a nice glass case!
Old 06-27-2011
MickeySaleen MickeySaleen is offline
How much does this service run?
Old 06-27-2011
There are a couple of variables, best explained over the phone. Give us a call if your in need to get this done.
We just finished another sc service on Friday on a car with no forseen issues...supercharger oil was nearly empty and a pice of metal went for a joyride inside the supercharger! We will get it wrapped up today and post some pics.
Old 06-28-2011
mikebna mikebna is offline
After seeing the original pics from that SC that S281 Motorsports worked on, made me realize it was time to have mine inspected and the front bearing upgraded and replaced as it was leaking from the snout.
Very glad I had it done by Mat and Jason. I was able to see the damage done to the other one in person at their shop in Fullerton.
Old 06-28-2011
Thanks Mike! Certainly makes us feel good to know you drove so far to come to us!
Old 08-14-2011
bruiser1010 bruiser1010 is offline
I have a 2007 S281 with 17k miles and just inspected it per your directions below. Where about on the spout is it most common to leak? I notice that I have the blue sealant, but from what I can see on the left and right side(s) I don't see any oil? It actually looks clean besides the blue sealant on the edges. I haven't gotten a chance to examine the bottom of the spout yet, I mainly looked to where your arrow points as directed below in the main pic. When I check the fluid, is it suppose to be completely filled to the top of the hole (of course leaving enough room for the plug)? Other than it being completely empty, how will I know how much oil should be in there when full? Sorry if this sounds like a dumb question.. Any and all info will help! Thanks a bunch!
Old 08-14-2011
I inspected mine last weekend and I have the leak. The snout appeared to be "sweating" and wasn't an actual drip. It was coming from behind the pulley and on the backside of the snout. I took the supercharger off and had about 5 oz left. Nothing appeared damaged, but I have ordered an upgraded snout from Jason @ 281 Motorsports. He is very helpful. Thanks Jason!
Old 08-14-2011
To help you with your inspection I have a picture of what mine looked like.
Old 08-14-2011
I just examined underneath the snout towards the pulley, which is the closest I could get without taking anything off, and noticed a bunch of powder-like black dirt and can't tell if their is a leak. However, I then looked at the driver-side snout bolt and it seems to be a bunch of "sweating" around that area. I would assume this means their is a leak? When you checked your fluid level, did you remove the all surrounding parts in the way, because it looks you have to remove the intercooler hoses and stuff to get to it? (I am familiar with cars, just not supercharged ones, yet). How much did it cost to get the new snout from Jason?
Old 08-14-2011
You may not need to purchase another snout unless the oil is coming out of the front seal by the pulley. If it is just leaking at the mating surface to the supercharger, you would just have to re-seal it with the upgraded red sealant. To properly check how much oil you have left in your supercharger you need to remove the entire assembly from the car. You will have to drain the coolant from your intercooler and radiator and be careful when removed the crossover so you don't spill a bunch of coolant in your engine. It really isn't that difficult to do....maybe 2 hours or so for your first time. Best bet is to contact Jason @ 281 on Monday and send him pictures, etc and he will set you straight.
Old 08-15-2011
ubnhad ubnhad is offline
Banned
You dont have to buy a new snout. The seal is replaceable. Found that out after I purchased a new snout on mine when it was leaking.
Old 08-15-2011
How do you change the seal? Where did you get it from?
Old 08-15-2011
Banned
Talk to Jason at 281 Motorsports. I gave him the info on the seal a few weeks ago. He should be able to help you out.
Old 08-15-2011
I will wait to see what Jason's response is and act as necessary.
So other than seeing the leak, will the supercharger act differently (or make noises) to alarm you that something is wrong with it? I always noticed that my supercharger "felt" like it lagged since I purchased it. (I bought the car with 3K miles on it.) For instance I would go full throttle and it would go thru the RPMs and around 4K get a sudden burst, even though the boost gauge would read full boost throughout.
Old 08-15-2011
Daytona1783 Daytona1783 is offline
So I checked today and mine is leaking too. I called Saleen and talked to Jess about the issue. He was very helpful, but he stated that because the car is out of its 3 year warranty, there is nothing that can be done other than having it serviced by PAS or a Saleen dealer.
My car has 9000 miles on it, and you can tell by the oil around the snout and supercharger body that it has been leaking for a while. I cannot believe a company would not stand behind something that they know is a design flaw and make the customer pay for it, even if the warranty is expired by 6 months. To be honest, I am a little disappointed.
I called PAS and talked to Jimmy. It is going to be around $200 to service the leak.
Old 08-15-2011
Daytona, I think it really all depends on if you need to replace your snout or not. Ubnhad says you can just replace the seal if it's leaking by the pulley which should save some money. The sealant isn't very expensive and the oil is about $50 so it really depends on if you are going to take it to a local shop and have it done or try and do it yourself. Jason @ 281 has a good price for a full supercharger service, but you would have to ship it to them. He can give you those details.
Old 08-15-2011
06281E 06281E is offline
Anyone know how much it will cost to service this problem?
Well now we know why Steve Saleen sold out, and why Saleen doesn't produce cars anymore.. It is disappointing, although so is misrepresenting the power output of the cars they build. I personally think they should pass a law that makes auto makers post the RWHP figures of the cars they build only because the CHP is just a joke and they can manipulate it any way they want... Lets see them sell a 450WHP Saleen Extreme for $75k...
Old 08-15-2011
Banned
Default Snout seal pictures
Size:  185.2 KBThis is what it looks like to replace seal. Probably can been done on car.
Old 08-15-2011
Sounds more like the standard tune issue. Mine no longer has that problem, one of the very first things I fixed.
Old 08-15-2011
Hopefully if you just try the seal it works, I just wanted the reassurance that I would not have to do it again by doing the whole nose cone assembly, with a new bearing, new seal, new gasket, new oil, and sealed better to the SC housing, plus a full inspection for other potential problems. Money well spent IMO.
Old 08-15-2011
I currently live in Columbia, MD and would consider driving the car to Richmond, VA to see PAS. What did Jimmy say that would be included for the $200? How do you feel after speaking to him? Will they inspect for further damage beyond the seal?
Old 08-15-2011
Was this a common problem?
Old 08-16-2011
Banned
Bad news! Looks like the info on the seal I gave Jason is not the correct seal. I am looking into a second source. It may be a few days before I know anything.
Old 08-16-2011
He said that changing the seal and adding the fluid would take about 2.5 hours plus the cost of the new supercharger oil would be right around $200. I called and talked to Jess Albright at Saleen and he recommended PAS. I assume they do good work because they are a Saleen licensed installer, the only one in VA that I know of, and were directly recommended by Saleen. I assume they will inspect for further damage once it is all apart.
Old 08-16-2011
lcats's Avatar
lcats lcats is offline
My 07 just hit 3000K - I bought it in 2010 as a dealer leftover. I notice that my windshield is speckled with what looks like oil - or maybe coolant? Is this normal or could the SC snout be the problem? I will rip it apart this winter - maybe it is still under warrant?
Old 08-16-2011
THANKS JOSH!
Bruiser, send me a pic to my email and ill take a look, but it sounds like your snout is leaking. A new snout is $299.
We are looking into the long term durability of this right now.
The supercharger will act fine all the way up untill it runs out and starts melting the gears/drive assembly. On the boost lag situation, check the bypass valve.
Guys, the problem is obviously pretty complex and there are quite a few varibles that make these fail. Sitting for prolonged periods of time (weeks, months) cause the seal to dry up would be the first issue. Your car is a 4 year old car with 9k on it, thats not a normal service duty. Im paying $400 to have an impellar changed on my boat because it sat long and dried up. Cars need to be driven and seals lubricated. The condensation, oil vapors, fuel vapors..etc eat seals up....DRIVE THE CARS!
Mike, How is the car running??
Guys, from everything I know PAS does great work.
lcats, that would not be the Supercharger. Sounds like a bad heater hose and its leaking near your firewall if its coolant. Get that looks at ASAP.
Old 08-18-2011
Saleen12c's Avatar
Jason,
Can you tell me what brand and model of supercharger oil you recommend? I couldn't make it out on the picture you posted earlier, and where do you check the level and pour it in? Sorry if this is a really ignorant question.
is it this?
Motorcraft supercharger oil XL-4 (4 oz. bottle) (do you need 4 of these bottles to fill it up?) becuase 16 oz. = 1 pint....correct?
http://k-mansparts.com/items/misc~fo...xl4-detail.htm
or
http://www.brenspeed.com/saleenoil.html
2008 S281 S/C Convertible #12c ("c" stands for Canadian made Saleen version)
Old 08-18-2011
The motorcraft oil is what I was told to use and I was told only 8 oz was necessary.
Old 08-18-2011
Cobrat16 Cobrat16 is offline
Can anyone suggest an installer in Las Vegas? My 07 extreme is at 20K miles and I see light dust pattern around the perimeter of the supercharger seal, seems mine may need some attention.
Old 08-19-2011
Banned
If its just dust and not oily.Its probably normal belt dust.
Old 08-19-2011
Banned
I spoke with Chanler at Breenspeed this morning he couldnt tell me how many ounces of oil to add just fill it to bottom of plug & to use the oil they sell and not use the Motorcraft oil. Then I call Jim Jr at JDM Engineering and he told me the Motorcraft oil is the same thing and that I would be fine. I have 8 ounces of Motorcraft supercharger oil in mine!
Old 08-19-2011
Hey guys,
Confirmed - it is 8 ounces or two small bottles of sc oil from ford. Each of the little bottles is 4 ounces.
  #45
Old 08-19-2011
Cobrat16,
You literally have no one in the lv area to go to. I've had customers have bad experiences from shops there. They just don't have a clue with these cars. Either bring it to us (which can be done in under a day), or do it yourself at home and we"ll attempt to walk you through it, you'd be better off. Give me a call on Monday if you'd like.
  #46
Old 08-19-2011
Banned
Excellent!! Thank you Jason!!
  #47
Old 08-19-2011
Originally Posted by Jason @ 281m View Post
Hey guys,
That's how much you put in mine right?
  #48
Old 08-19-2011
mdctiburon mdctiburon is offline
Jason just checked mine guess what my 2007 is leaking too. can you either reply here with prices for snout or seal repair kit any other things thay may be needed or would you just suggest going to PAS???????
[SIGPIC][/SIGPIC]
07-145 SC, Brenspeed Stage 3 Kit, Optional Forged 5 Spokes, Vista Blue
  #49
Old 08-20-2011
Ok guys, I got my car back today. Total cost to service the supercharger was $357.82. That includes all fluids (supercharger oil, anitfreeze, red sealant) and the 3 hours of labor to complete the job.
I also had an issue with my intake tube, which had melted to to oil build up around the throttle body. That cost me another $120 for a new intake tube.
All in all, I am very pleased with the work PAS did. Mark and Jimmy are great to deal with. They even washed and waxed my car and detailed the interior. For those who are on the fence, take it to PAS, they will treat you right.
  #50
Old 08-20-2011
Got mine done today too. You got a good price. I did it myself and it cost me about $400, but I bought the new snout. Cost me a little more than that since I decided to install an MGW shifter and change tranny fluid with Royal Purple Synchromax...:)
