Old 10-01-2017
mamorteguy mamorteguy is offline
Default Q: S281 SC Vacuum Plugs? - 2000
I noticed on the rear of my supercharger there is type of "vacuum tree" with about 5 vacuum tubes, some of them are plugged, some are not, my question is "Are the all supposed to be plugged" or some open, and if so, which ones are supposed to be plugged? any help with this would greatly appreciated, it has a real miss between 2100 and 3000 at times, and I'm wondering if this might have something to do with it? Thankyou
Old 1 Week Ago
OxfordS281 OxfordS281 is offline
I will take pictures of the back of my series 1 tree. Did you check your gasket below the supercharger that seals it to the top of the intake manifold? Mine is worn and cracking and now extra air is being sucked into the intake, after the MAF, causing bank 1 to run lean and a check engine code. The miss between 2100-3000 sounds like it could be a spark plug issue, or a coil plug not giving the spark plug spark, causing it to miss. Are your plugs and coil plugs original?
1996 #222 1 of 21 in Moonlight Blue 1 of 8 with exact options
3:55's F-Leather 2 Point Chassis Brace
1999 #259 3:08's Chrome wheels, Supercharged, Floormats.
Old 1 Week Ago
I have changed the plugs, but the Coils are the same, but I have pulled one coil at a time when running to see if there was a dead spot but they all sounded the same, but that's not to say that one is bad, but I'm getting no codes when tested, and when I got the code the first time on cylinder 3, I replaced the plugs, and the injectors, the EGR, TPS sensor, cleaned the MAF , and the codes went away, it still has a miss, and just recently, its begun to idle badly, the warmer the engine gets to the point of actually stalling, the timing jumps around from 6 degrees to 22 degrees? I'm stumped !!
Old 1 Week Ago
Could it be an injector issue?
Sent from my iPhone using Tapatalk
Old 1 Week Ago
I certainly hope not, they were just replaced about a month and half ago, and I'm sure you know was no easy task with the supercharger being there?
Old 1 Week Ago
Original fuel filter?
Old 1 Week Ago
That's what I was going to try next, it replaced about 5 years ago when I had to replace the a bad fuel pump, but it may have clogged up. The only problem is that when I get an the gas, it pulls hard, and I just assumed if the fuel filter was clogged up it would not let more fuel by, but I'm running out of options. but "Thanks for the suggestion", I'll feel like an idiot if that's what it is.
Old 1 Week Ago
Did you happen to take a picture yet ? If you have, could you please post it so I can compare, with all the stuff I replaced, I fear I may have knocked of a plug , and I may be plugging something that shouldn't be, Thankyou!
Old 1 Hour Ago
6 pm plugged
9 pm pcv
10 pm plugged
1 o clock FP switch
2 pm plugged
5 o’clock vac line to egr control solonoid and AC vent /evap splice
Old 1 Hour Ago
| SOEC.ORG | ABOUT SOEC | MEMBERSHIP | MERCHANDISE | LITERATURE | VEHICLE PRODUCTION | SALEEN LOCATING SERVICE | SALEEN AUTOMOTIVE | CONTACT SOEC | SOEC @ FACEBOOK |
All Original Content Copyright © 1991-2017 Saleen Owners and Enthusiasts Club, LLC (SOEC). All Rights Reserved.
