Old 02-14-2015
mosaleen's Avatar
mosaleen mosaleen is offline
Default Help: Measure Thump tensioner & mosaleen systems?
I need someone having thump tensioner to measure the base that the bolts bolt it up.
need front to back measurement of the base only. How thick?
Or if anyone has Mosaleen Grip plate system with Thump r tensioner can you measure the two spacers....(one between plate and where stock idler was removed & just the spacer protion of the spacer between
plate and my idler pulley that has sides on it (not the portion that goes into idler pulley).
Thanks Scott
Got it taken car of.... Thanks
3:73 gears, Watts link Gen II
