Old 05-30-2017
john03-259 john03-259 is offline
Default Q: Replacement Blower Bypass? - 2004 Series IV
My bypass valve has separated from its metal bracket (car would not make boost) Does anyone know where I can find a new one? I found new ones for 05-10 and they look identical. Anyone aware of them being the same?
here is a link:
http://www.ebay.com/itm/Saleen-Super...-/371914021840
Thanks,
John
Old 08-08-2017
bobne bobne is offline
Registered Users (Inactive)
Default ByPass Valve
John, did you ever get an answer to this?
I'm looking for one also. I don't believe the one you referenced on eBay will fit since it looks like it has two connections for hoses. The one on my 2001 Saleen SC only has one connection (which I broke off!).
Old 08-11-2017
I've gotten a replacement boost bypass valve before for my car wayyyyy back when. See this thread for part number for the series II M90. I'd call magnusson and ask if they have one for the series 1 which is still an eaton M90 iirc. Part number is at the bottom. You can double check with them. I think the magnusson bypass link is dead in that thread but you can go to http://www.magnusonproducts.com and give them a call about it and they should still be able to help you.
http://saleenforums.soec.org/archive...hp/t-8696.html
07 Porsche 911 Turbo
02 Saleen S/C Speedster
3.73 gears
Chicane 66mm Pulley
SCT custom tune
SVT Focus Fuel Pump
13" Brembo Brakes
TorkTech Intake
SVT Cobra single blade TB
Chicane Intercooler
42lb injectors
90mm MAF
FPRP Aluminum Driveshaft
