2010-2014 Saleen Mustang For the SN10 platform California-built 2010 SMS 460 and 460X, the 2011-12 SMS 302, and 2013-14 Saleen 4V, SC, SSC and 351. All Label cars (White Yellow, Black). Be sure to specify year, model and equipment if asking for help. |
Q: 2010-12 HID retrofit?
Anyone know who makes these?
I really like them as they keep the 2011 headlight to marker realtionship. |
raxium did....but I think they only make projectors now.
Are the 2010-12 turn signals on a separate harness from the headlight?
If the standard 2010-12 headlight reflector is the same as the standard 2005-09 reflector... and if the turn signals are independent from the headlight... it may be possible to take the guts from a 2005-09 Saleen HID light and place it in the 2010-12 housing. Would be a costly and time consuming experiment. |
Here, check out these site for Halo types of lights:
http://www.nfcperformance.com/ford-m...alo-headlights http://www.americanmuscle.com/oracle...sion-1012.html
My Build: http://saleenforums.soec.org/showthread.php?t=6881 Wind Deflector: http://www.saleenforums.soec.org/showthread.php?t=12930 Last edited by Coderedsaleen; 01-01-2014 at 12:53 PM. |
Okay, now that you have clarified what this actually is, I really want more what the 2013's have but are arranged in the 2012 confiduration. I'll have to look at the wiring to see if it is seperate.
Probably would be easiest to retrofit the 2010-12 HID lights or the 2013-14 HID lights.
Looks like the reflector in the standard 2010-12 headlight is missing the top of the circle. IE: The reflector is not a complete circle. The 2005-09 headlight reflector is a circle. On the SVT Forum someone did retrofit the 2013-14 HID headlight assemblies to a 2012 Boss 302. |
Is there a difference between the 2010-2012 and the 2013-2014 units?
I may be mistaken, but the front markers/signals are lit with the headlights in 2010-12. In 2013-14 the front markers are the LEDs and the yellow signals are only lit during a turn indicating. |
Here is a 2010-12 non-HID assembly retrofited with a projector lens for HID use.
Custom 2010-12 retrofits.
These things are sweet. I would like to keep the amber markers though. I will check out their website. Thanks!
Someone used a modified version of this harness to run the factory HID lights: - http://www.theretrofitsource.com/pro...ducts_id=14029 - http://www.allfordmustangs.com/forum...483-post1.html A retrofit: - http://www.modularfords.com/threads/...alogen-housing HID parts: - https://www.theretrofitsource.com/ |
