Old 01-12-2013
Mexicoya Mexicoya is offline
Default Q: Supercharger oil change? - 2006
Hi, I need to change the oil on my 2006 SC with 50,678 miles. I took to local Ford dealership and they would charge me $275 to do. They said the alternator has to be removed in order to do it. I read the threadthread on the forum about the oil replacement and it said to make sure all the oil is siphoned. It said nothing needs to be removed. Any idea if this is true? Also, can i do myself? I'm no mechanic, but i do all my oil changes, so I'm willing to get dirty. Where can i buy the new oil to replace and how much does it cost? Any guidance is greatly appreciated!! I live in the Bay Area, GO NINERS!!!
[FONT=Palatino Linotype][SIZE=4][I][B]Victor M. Osorio[/B][/I][/SIZE][/FONT]
[FONT=Palatino Linotype][SIZE=4][I][B]2006 Saleen SC # 1567[/B][/I][/SIZE][/FONT]
Old 01-12-2013
Razorbed Razorbed is offline
You need to remove the water crossover to get to the oil screw. The best way is to buy a large syringe and a hose, so you can suck the oil out. No need to remove the alternator.
You can buy Ford XL4 oil or GM 12345982 supercharger oil. There are even sets on ebay that include the syringe. The supercharger takes about 6oz. of oil.
Old 01-12-2013
jaymoo7's Avatar
jaymoo7 jaymoo7 is offline
The correct way to do it is to removed the supercharger, drain what oil you can and ship it to Jason at 281 motorsports for correct servicing. There is more to it than sucking the oil out and putting new stuff in. Give him a call and talk to him 877-281-6878.
2006 Saleen SC-#1391 Black, HTO plugs, vacuum line upgrade, 60lb Injectors, 3.2 Saleen pulley, Saleen Extreme CAI, mosaleen idler system, Gt500 dual pumps, MGW short throw shifter, Kooks LT w/catted H pipe , SCT X3 programmer( JDM Tune), AFCO Heat Exchanger, JPC intercooler Tank, Fluidyne radiator.
Old 01-14-2013
Thanks for info guys. I do drive my car daily, so not sure taking off SC is an option. Any other advice on how to do it or where to take to get it done?
Old 01-14-2013
jaymoo7's Avatar
I drive mine daily as well. But to have it done correctly and have a better piece of mind, I made that sacrifice.
Old 01-14-2013
Kendog's Avatar
Kendog Kendog is offline
Talk to fun girl she lives up your way there are a few good shops in N. Cal
08 S302E Coupe #01 "Black Ops" USSOCOM Tribute Car. Sponsored by 281 Motorsports, HRE, Cortex, BMR, Aeromotive, Barton, ACT, SCT, Schroth, CSF & Toyo Tires! Mods to numerous to list! God bless our Special Operations Soldiers and their families!
Old 01-14-2013
How can i get in contact with fun girl?
Old 01-14-2013
Nightstalker's Avatar
Nightstalker Nightstalker is offline
http://www.tpsmotorsports.com/company/
^ You can have it serviced here. They are located in Campbell.
12 Boss 302 -0948 Performance White
12 F150 SVT Raptor SuperCrew Ingot Silver
Old 01-15-2013
Kendog's Avatar
You can send private messages here on the forum her name is actually FUNGIRL just PM her and ask her where she gets her Saleen serviced! We have a few members in No. CAL
Old 01-15-2013
Just sent, thx!
Old 01-16-2013
Just sent, thx!
Victor,
If you decide to have us do the full maintence on your supercharger, its only a 1 day process if you schedule it and if UPS/Fedex drops it off early enough, its possible to have it shipped out the same day. But there much more to the "needed" service than just changing the oil.
You can pick up the oil however from Ford, or we sell it bottled up in a correct 8oz bottle for $29.99
Old 01-21-2013
Thanks for the info Jason! Still not sure which way I'll be proceeding.
Old 01-21-2013
No problem, just let me know if we can help.
Old 01-23-2013
Gray is Grey's Avatar
Gray is Grey Gray is Grey is offline
Here is the tool to use:
http://www.tooltopia.com/vim-hbr5.as...googlebase_18u
You will still have to remove the alternator (be sure to disconnect battery first), but this will get you in there without removing the coolant crossover, the small ratchet teeth will get you 2 clicks per turn.
Install your bit into the ratchet upside down and I used a dab of anti-seize to hold the oil plug onto the bit.
05-653 Mineral Grey
Brenspeed Stage 3 / Aluminum hood / Shaved antenna / This,that and the other.
Old 12-12-2018
zeitmorder zeitmorder is offline
This VIM tool is a godsend for getting the supercharger fill plug off without having to remove the coolant crossover. Literally 2 micro-clicks per turn of movement. Had to get a finger in there to hold the plug once it got more loose, but eventually it came out.
I ended up buying several to keep in my various toolboxes at work and home.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 12-12-2018
We will have to look at this, but if you drop the plug it will be a bad day trying to get it! We also make a dipstick kit you could buy to check and top off oil so you dont need to do this.
Old 12-12-2018
Damageln Damageln is offline
I can without a doubt vouch for Jason and his team. I sent my supercharger in from Florida and they kept me in the loop and his turn around time is as he said. They installed the dipstick to make checking the oil WAY WAY easier.
Old 12-12-2018
Thanks sir! I'm still digging for a box for your steering wheel...lol. I'll go buy one if I have too...
Old 12-12-2018
LoL no problem! Expect a call soon about upgrade cooling (engine and supercharger)
Old 12-13-2018
Awesome!!!!
