Old 12-07-2011
Rayder_K Rayder_K is offline
Default Q: Does Saleen Make Wider Wheels?
Hello everyone, I was wondering if saleen makes their rims in wider sizes, like maybe 295 or 285? I don't like the stock size?
And if they do, where can I get them?
Old 12-07-2011
Barricade's Avatar
Thats the tire size. Most of our wheels (05-09) are 9" up front and
10" in back and either can easily support 285 or 295.
Barricade is rocking 285's on his back end.
-ǝsınƃsıp uı ʇoqoɹ-
BARRICADE 643
06-108E
Old 12-07-2011
All 99-04 wheels are 18" in diameter. Front wheels are 18x9, with a 25mm offset. The standard rear wheels are 18x9 also, but with a 12mm offset. The optional rear wheel was 18x10 with a 30mm offset.
The silver painted finish was standard, chrome optional. White, yellow, and gold finishes are also been seen. Chrome wheels had chrome center caps and lugnuts, while painted wheels had silver center caps and black lugnuts.
Standard tire sizes were 255/35/18 (Front) and 265/35/18 (Rear) unless the 10" upgrade was ordered. With the upgrade, front size increased to 265/35/18 and rears were 295/35/18.
I had mine widen to 11'' rims and sporting 335's Pirelli PZero Neros.
Old 12-08-2011
Originally Posted by Coderedsaleen View Post
I had mine widened to 11'' rims and sporting 335's Pirelli PZero Neros.
Where did you get them widened, Codered? The place in Michigan?
07 Porsche 911 Turbo
02 Saleen S/C Speedster
3.73 gears
Chicane 66mm Pulley
SCT custom tune
SVT Focus Fuel Pump
13" Brembo Brakes
TorkTech Intake
SVT Cobra single blade TB
Chicane Intercooler
42lb injectors
90mm MAF
FPRP Aluminum Driveshaft
Old 12-08-2011
Where did you order the bigger rims, with the 295 size?
Old 12-09-2011
I got them widened here locally in Hampton at a place called Craft Repair Inc (http://craftrepair.net/). $150 per wheel and they do an excellent job.
Saleen has a 10'' rim and you can get a 295 from any tire place. Saleen Speedlab still sells them... Well I guess not, I just check their website and they don't list them any more. They just have the newer styles.
Old 12-14-2011
coachfarnen coachfarnen is offline
So, when you widened them did they just make the outer lip an inch wider? 335s would look sick on my car!!!!
Old 12-14-2011
No they split the rim and then added a wider band in the middle. Here are my 335's.
Old 12-14-2011
With the offset the Saleen rims have made widing the rims fit nicely in the wheel wells with no spacers. They only thing I had to do was remove the kicker shock, I do have a slight rub only when I do hard turning to the right.
Old 12-14-2011
Yeah they look sick.... I would love to do a real serious set-up similiar to the new vettes. Like 19s up front and 20s in the rear but I'm not sure I'm ready for the time and $ commitment yet. For now if I add an inch to the 18s that would be great but I would love to get some 335 drag radials if I can find them. Need something a tad more sticky for the tourque of the 351. How difficult was it to remove the shock and how did it change the overall ride? Sweet car BTW...........
Old 12-14-2011
The shock it very easy to remove, two bolts for the shock and two bolts for the top mount(per side). Didn't change the ride all, they are for wheel hop. I still don't get any with the much wider tires.
Thanks for the compliment!
Old 12-15-2011
Hey, I also had to as you.... Where did you get that rear wing/spoiler? That's bad ***. Looks like it may be from an Extreme? If it is and you did the work how difficult was it to mount? I really don't want to have to drill any more holes in my car.... I can tell you did your exhaust like the Extreme as well. Thanks
Old 12-15-2011
The three piece rear wing I bought from Saleen in 2003. I didn't have to drill any more holes in the decklid because it uses 3M VHB tape and two screws that screw through the original holes for the OEM wing. The side pieces are held on only with 3M VHB tape.
Yes I went with the center exhaust because it was different at the time, also 2003.
Sorry not trying to highjack the thread.
Old 06-01-2017
Sinner Sinner is offline
How did change the offset to bring the wheel farther out?
Old 06-28-2017
The wheel sits in the same location but now it goes deeper into the wheel well.
Sent from my SM-G900P using Tapatalk
Old 06-30-2017
Wow, I'm surprised that you didn't have to run a spacer
