Old 03-06-2018
KGinPA KGinPA is offline
Default Help: IAT Gauge erratic behavior - 2007 S281 SC
I recently purchased 07-411 S281SC Convertible and the weather has been terrible here in PA so I haven't driven the car more than down the street and back. However, I noticed the Intake Air Temp gauge indicator bouncing from side to side while under power. Have any of you had that issue and what have you found to be the cause? It doesn't move while at idle.
Old 03-07-2018
Meeker1's Avatar
Meeker1 Meeker1 is offline
I had the same needle bouncing back and forth on boost gauge . . purchased new gauge from Speedlab but also erratic reading and returned . . Speedlab suggested checking sending unit and replace . . Would be great to hear from others on fix . .
Old 06-04-2020
Meeker1's Avatar
Still could use help and reply . . annoying issue and boost gauge still not working . . getting ready to pull her out from winter / virus storage and drive #1264. . Thnx
Old 06-04-2020
Did you replace the sending unit? That’s the only other thing that makes sense to me.
Old 07-12-2020
Meeker1's Avatar
Took a much closer look after ordering a new $50 sending unit from Velocity Products on ebay . . noticed nut that was supposed to be attaching unit was held on by a small zip tie . . unbelievable . boost gauge works great after replacing nut .. unfortunately Velocity Products will not take return on purchased unit . . Oh well
Old 02-14-2021
06 Saleen 06 Saleen is offline
Has anyone founded anymore information on this problem.
Old 03-08-2021
Damageln Damageln is offline
Mine was resolved when I replaced the air temp sensor (shared part with the Ford Lightning.) I also changed the intercooler pump and I haven't had an issue in over 2 years.
Old 07-08-2021
06redsaleen 06redsaleen is offline
Default Air temp guage sensor replacement
Noticed you had a problem with your air temp guage and replaced the sensor to solve the problem. Where did you buy it and what was the part number?
My guage pegs as soon as I turn the key and remains there. I have traced the wiring and didn't find a problem which leads me to believe the sensor is the source of the problem. Appreciate the help!!
Old 07-10-2021
Meeker1's Avatar
I have an extra brand new sensor . . $40
