Go Back   The Saleen Forums at soec.org > Saleen Mustang Discussions > 2010-2014 Saleen Mustang
2010-2014 Saleen Mustang For the SN10 platform California-built 2010 SMS 460 and 460X, the 2011-12 SMS 302, and 2013-14 Saleen 4V, SC, SSC and 351.
All Label cars (White Yellow, Black). Be sure to specify year, model and equipment if asking for help.
  #51
Old 03-13-2014
Werecow Werecow is offline
Originally Posted by JasonsSaleen View Post
The fronts were easy and only took about 2 hours. The rear brakes took the longest because I had to drain the diff. and pull the axles to install the new caliper mount. The rear rotor went up in size to 13.8".
Since I last posted, I installed Koni Sport Struts/Shocks and a Barton short throw shifter. I'm saving for a supercharger and boss manifold. Should have them by the end of the year. My goal is 650 rwhp.
Probably will need more fuel too... I was told that 600 RWHP is about the limit for the stock fuel pump.
  #52
Old 03-13-2014
Kazoo DUDE Kazoo DUDE is offline
and the injectors are 32lbs or 39lbs not sure but not enough. I would also suggest the whiteline tranny bushing so you limit the twisting that much power is going to but on the MT 82.
  #53
Old 03-13-2014
JasonsSaleen's Avatar
JasonsSaleen JasonsSaleen is offline
The kit that I've decided on is from Beefcake racing and comes with injectors and a boost a pump. I haven't looked into the driveline changes yet. I'm sure I will have to strengthen some things due to the increase in horsepower. I will do and learn everything little by little.
Thanks for all the great advice!
  #54
Old 03-14-2014
this is the bushing $65 and with my Barton shifter bracket, I have tightened up the shifting nicely. I use to miss hard 2-3 shifts but these two things eliminated it. You can read up on them at American Muscle or cj pony parts. Enjoy the new ride!!
http://www.americanmuscle.com/whitel...-kit-1114.html
  #55
Old 04-23-2014
After a couple of weeks with the new shifter, I realized that I did something wrong while installing it. There was a whine every time I touched the shift knob to put it in gear. I could also hear a lot of driveline noise as well. I pulled the shifter out and realized that I didn't have the boot ring intalled back around the sheet medal opening. I installed dynamat and repositioned the boot correctly and eliminated the noise. The shifter is great and functions perfectly. A really good upgrade if you're considering a short throw shifter.
