Old 02-13-2014
s302yl20's Avatar
s302yl20 s302yl20 is offline
Default Help: 1997 Mustang steering wheel play
Hi everyone,
I was wondering if anyone could help to give me and idea how to get rid of my 97s steering wheel play? It doesn't have a lot, just a little.
What I mean by the play is, you can move the wheel back and fourth like your turning, just a little... without the car actually engaging into the turn
it's annoying, the car 94k on it so it might be a little understandable but... I just can't handle it
thanks!
2014 S302YL #20
2002 S281SC #64*
1996 S281 #220*
*sold cars*
Old 02-13-2014
With fox era Mustangs, I knew steering wheel play usually meant the rag joint needed replaced.
Old 02-14-2014
Werecow Werecow is offline
I put the Maximum Motorsports version in my 1989 Saleen and it made quite a bit of difference. The rubber rag joint starts to get a little sloppy over time.
Old 02-14-2014
s302yl20's Avatar
thanks guys I'll look into it
2014 S302YL #20
2002 S281SC #64*
1996 S281 #220*
*sold cars*
Old 02-17-2014
Maximum Motorsports Steering shaft and aluminum rack bushings helped that for me. It used to drive me NUTS.
I don't know which one helps more because I did them both at the same time. You could also consider the polyurethane rack bushings (instead of the solid aluminum rack bushings). I would do both the shaft and bushings.
07 Porsche 911 Turbo
02 Saleen S/C Speedster
3.73 gears
Chicane 66mm Pulley
SCT custom tune
SVT Focus Fuel Pump
13" Brembo Brakes
TorkTech Intake
SVT Cobra single blade TB
Chicane Intercooler
42lb injectors
90mm MAF
FPRP Aluminum Driveshaft
Old 02-28-2014
hfnav hfnav is offline
The 93 Cobra was soft shocked by design and was understood to use them up in a few 10k miles. I'm talking 1/4 lane change on the Merrit Parkway with no input. Illumina shocks solved it 100% as most any replacement shock likely would have. I was amazed, and remember that quite well. It caused adrenalin rushes of the unwelcome type. Perhaps the concept applies to your 94k mile ride.
Old 03-02-2014
What he said.
Old 03-31-2014
Saleen_S351 Saleen_S351 is offline
Did you get your problem fixed?
JMB
1998 Saleen Speedster (S351 SC) #14
Black on Black
Old 01-20-2016
killer454 killer454 is offline
I had same problem play in steering wheel turned out to be the compresion joint in the steering shaft they put a plastic sleeve in it and it deteriates after a long use causing play in the shaft.I bought a 400 racing steering shaft no play now
