Go Back   The Saleen Forums at soec.org > Saleen Enthusiast Forums > TSBs, Install Manuals and Service Documents
TSBs, Install Manuals and Service Documents Technical Service Bulletins and other resources to help you keep your Saleen running in top form. Full access is available to forum registrants. If you can't find a document, please PM us or use the Contact Us form at the bottom of the page with year, model and concern.
Closed Thread
Old 04-21-2008
We've received a lot of questions by e-mail about the inspection and service of the twin-screw supercharger oil on late-model Saleens.
"The photo [below] shows the location of the fill plug on the supercharger," says Saleen engineer, Andrew Gardner. "The plug is removed, but the threaded hole is visible on the [center] side of the photo. Several components have been removed in this photograph to show the location, but it is straightforward to find. The oil should be replaced every 50,000 miles and it doesn't hurt to check more often. The plug is removed with an Allen wrench, and it can be done without removing any other components."
Billy Tally, Saleen's former chief officer of technology explained to us some time back that the 50,000-mile service interval is on the conservative side. The high-quality lubricant used from the factory doesn't need to be changed as often as engine oil, especially since there is no exposure to hydrocarbons or other contaminants. It's simply gears rotating, and the unit really doesn't get all that hot.
Many thanks to these gentleman for assisting us with this question, and owners should routinely inspect the oil level should something unforeseen happen -- better safe than sorry.
Old 04-21-2008
Default Series VI Supercharger Manual
Saleen owners with this supercharger should consider keeping this download handy for maintenance and diagnosis -- at least you can be better informed should you take the vehicle in the dealer for service.
File Type: pdf SaleenSCMaintenanceManual-SeriesVIandTruck.pdf (454.4 KB, 32 views)
Old 06-08-2008
Default 2007 Parnelli Jones and 2007-09 Heritage Series Reference Documents
PJ Instrument Cluster Removal for Reprogramming
Old 06-08-2008
Default 2007 PJ Black Paint Care
Old 06-08-2008
Default 2007 PJ Watts Link TSB
Old 12-29-2008
Default All Saleen Vehicles - Flat Spotting on Tires - STSB08-009
All Saleen Vehicles - Flat Spotting on Tires - STSB08-009 - December 1, 2008
SERVICE INFORMATION: Procedure to repair "flat spotting" on tires that have been sitting for a period of time.
IF YOU CONFIRM: The vehicle has a vibration while driving.
File Type: pdf Flat_Spotting_On_Tires_STSB08-009_SOEC.pdf (451.7 KB, 34 views)
Old 01-05-2009
2005-08 HID Mustang and S-Line Saleen Installation Manual PDF
Old 05-20-2009
2005-09 Rear Window Louvers Installation Manual.pdf
Old 05-20-2009
2005-09 Saleen Heritage Body Kit Installation Manual.pdf
Old 05-20-2009
2005-09 Saleen Supercharger + Supershaker Upgrade Kit Installation Manual.pdf
Old 06-24-2009
If you have squeaky brakes, the cause may be an improper bed-in procedure and could be cured with a simple do-it-yourself fix.
Old 08-04-2009
2005-08 Saleen Mustang Dual Fuel Pump Kit Install (should be applicable for 2009 as well).
File Type: pdf 2005-08_Saleen_Mustang_Dual_Fuel_Pump_Kit_Install.pdf (1.63 MB, 28 views)
Closed Thread
| SOEC.ORG | ABOUT SOEC | MEMBERSHIP | MERCHANDISE | LITERATURE | VEHICLE PRODUCTION | SALEEN AUTOMOTIVE | CONTACT SOEC | SOEC @ FACEBOOK |
All Original Content Copyright © 1991-2019 Saleen Owners and Enthusiasts Club, LLC (SOEC). All Rights Reserved.
