Old 08-08-2017
bobne bobne is offline
Registered Users (Inactive)
Default Q: Series II Supercharger Valve? - 2001 S281 SC
There is some kind of valve on the drivers side of the supercharger towards the back. There is a small hose feeding into the bottom front of the valve, coming from the fuel rail. While I was cleaning the supercharger I broke that fitting off.
I'm now trying to identify what that valve is so I can replace it.
Can anyone offer assistance?Click image for larger version
Old 08-11-2017
Are you talking about the part that says "caution do not lift here - factory adjusted?" if so that's your boost bypass valve.
Check the other thread for where you can find your answer.
Short answer: http://www.magnusonproducts.com call them and ask for an eaton M90 boost bypass valve and make sure it's the same for the series 1 as the series II. I'd imagine it's the same if i had to guess.
07 Porsche 911 Turbo
02 Saleen S/C Speedster
3.73 gears
Chicane 66mm Pulley
SCT custom tune
SVT Focus Fuel Pump
13" Brembo Brakes
TorkTech Intake
SVT Cobra single blade TB
Chicane Intercooler
42lb injectors
90mm MAF
FPRP Aluminum Driveshaft
