Go Back   The Saleen Forums at soec.org > Saleen Vehicle Discussions - Tesla, S7, Focus, Sportruck and XP > 2004-2005 Focus N20 and S121
2004-2005 Focus N20 and S121 Just for the Saleen N20 and S121 Focus cars.
Old 12-10-2013
Vboy13 Vboy13 is offline
Default Q: Nitrous install?
I have an 04 n2o focus and the nitrous has never been hooked up
This may be a stupid question but what all do I need that didn't already come with car to be able to run the nitrous? I see that I need a braided fuel line but other that what else? Do I need the main wiring hardness? And where does the other end of the fuel line go?
Thanks for the help
Old 12-10-2013
Saleen1 Saleen1 is offline
give me a call mine is all hooked up. 270. 860. 4789
1994 S 351 R #37
2004 Saleen N20 Focus #45
Old 12-10-2013
Thanks for the quick respond, but after hours of research last night I'm pretty sure I've figured it out.
I'm missing the fuel line
And the fuel rail adapter
And the rmp actived switch (saleen main harness)
Correct me if there is something else
And after further research I can orders these parts via saleen for $400+
Or buy aftermarket ones for $125. Just have to splice into those plugs that saleen put on the ends of their wires to wire up another rpm switch
Thanks again
Old 12-11-2013
Greg Wackett Greg Wackett is offline
Inactive Account
I have the saleen install guide I can email PM me your email address,
Greg Wackett
Old 12-11-2013
Inactive Account
Saleen had the rmp actived switch this wired up a special way. Saleen1 had one with is his car . if I can find the wiring set up I have the pig tails from saleen and we can reproduce.
Greg Wackett
Old 12-11-2013
Thanks Greg but I found the install guide that's how I got to the point of realizing I'm missing those 3 parts
Yes the wiring set up would be amazing! Be a great help to wire up another rpm switch from jegs
Also another question which is probably completely of that cub jet but you might know. In the truck by the n2o bottle I have some power and ground wires that look like they came with the car stock and I followed them up to the front and they go nowhere. They are just bundled up under the dash by the clutch no connected to anything. Do you know what these were for? Maybe so you can easily but a stock amp and sub back there?
Old 12-12-2013
busaandy busaandy is offline
im in the same boat as him. i wanna run n20 also.. vboy13 let me know what you figure out!!!
Old 12-13-2013
guys you cab buy a wide open throttle n2o switch from any nitrious company and set it up like saleen did with 3000 to 5,800 rpm,range. When I bought my car it had the saleen harness with it, but it had still never been hooked up. A local shop installed it for me (you will also need a 75 hp jet as the one saleen put in it is solid with no opening for the n2o to flow. You also need the fuel rail adapter to run the extra fuel line into. Finally, you need some dyno time to check the air fuel ratio. The first pull my car made nearly 230 to the wheels, but was wayyyyy too lean. We also had to change the fuel jet because it wasn't delivering enough fuel. Ended up making 202 hp to the wheels. Made 124 to the wheels off the juice.
1994 S 351 R #37
Old 12-13-2013
The jet that installed by saleen is solid? That I didn't know. Thanks
Old 01-15-2014
Cameron18 Cameron18 is offline
I have an extra junction block and fuel line with fittings if any one is interested.
Old 01-27-2014
How much? Shipped
Old 01-27-2014
Send me a PM .
Old 01-30-2014
is it for a 04 or 05 n2o?
Old 01-30-2014
It is for the 05 2.0.
Sent from my HTCONE using Tapatalk
Old 01-30-2014
is the line the same on a 04 and 05.. i know the fuel blocks are different
Old 01-30-2014
im guessing your the guy on ebay?
Old 01-30-2014
Not sure the line is -4 NPT 40 inches long.
Old 01-31-2014
Yes I have them listed.
Old 02-02-2014
send me a price for just the line
Old 02-03-2014
The question being how much shipped for parts, Send PM with price, list on eBay etc. Just to clear things up the parts are not going for free and they are authentic 05 Saleen focus parts. This is not a hit on anyone just get a lot of email traffic about items with no follow through.
Old 02-14-2015
jeffp0828 jeffp0828 is offline
Question N20 Nitrous Install Guide
If anyone has a copy of the install guide for the nitrous hook-up on a 2004 N20 Focus could I get a copy of it to see if mine is hooked up? All the lines look in place but the light on the dash switch does not come on so I do not know if the system is active. Thanks.
Old 02-14-2015
Firehead's Avatar
Firehead Firehead is offline
Greg Wackett may have this. Sounds like yours isn't.
Old 02-14-2015
How do I get hold of Greg? Thanks
Old 02-14-2015
Firehead's Avatar
Hopefully he'll see this but you can PM him here. User name is his name.
Old 02-14-2015
Sent Greg a PM. Thanks again
Old 02-14-2015
Firehead's Avatar
I've been eyeing a kit with the idea of attempting to reproduce it. Not sure I can sell enough to offset my expenses.
Old 02-14-2015
Everything looks like it is on mine (tank, lines, switch, etc) but just won't activate. Might try and find a local hot rod shop and have them check it out but would be nice to have the Saleen install papers when I do. Wish someone would reproduce the body kit in case you ever need any of those.
Old 02-14-2015
Inactive Account
sorry just getting back on line today I will check for your PM if you included your email I will send you the guide. You can also call me and Terry who listed his number earlier in this thread had his done and can help.
Greg Wackett
Old 04-27-2015
A shame that Saleen can not help with their own nitrous components and no one can seem to point who might could help.
Old 04-27-2015
I found the fella that made the N20 switch on LinkedIn. Sent Greg an email months back.
Old 04-27-2015
I sent Greg a list of what mine was missing and he said the parts would be hard to come by.
Old 04-27-2015
Inactive Account
The Saleen Specific parts are VERY hard to find the general N2O connection you can find through most N2O distributions. Talk with SALEEN1 here on the board he has is set up.
Greg Wackett
Old 04-27-2015
Wilson manifolds help me out when replacing some components of the nitrous system on my son's car.
