Old 08-23-2010
FATHERFORD FATHERFORD is offline
Default Fore Precision Triple Pump hat and Mosaleen idler
Not sure If I have made a proper introduction on this forum...
I have a 2004 F-150 XLT regular cab with a 5.4L. It has seen many parts in it's short lifetime. Anything from a full bolt on n/a truck, vortech blower pushing 12lbs(450rwhp/450rwtq) to now it has a Saleen Blower.
Current performance mod list:
Saleen Blower
2.87 Pulley
JDM Stage 1 system(Roush Intake)
Mosaleen Idler
LS1 Camaro Electric Fans
PI 2800 converter
OBX Longtubes
OBX Resonators
"custom" true dual 2.5" exhaust running through a Magnaflow Dual in/out muffler
Fore Precision Works Triple Pump Setup(Troyer performance sells)
4.11 Gears
JDM mail order tune
I have a dynotune set on September 3rd with PSI Motorsports out of Webster, Texas. I have been trying to get one setup with JDM when SR. is down this way, but we are both very busy people and can never seem to be in the same area at the same time. No fault of theres and I have been very pleased with their mail order tune and customer service.
I have yet to see any post on this forum about the following mods I installed a few weeks ago. I'll transfer the post I did to other forums on this one for future reference by other members.
MoSaleen Idler and the Troyer/Fore Precision Works Fuel Pump Setup.
Old 08-23-2010
**I have yet been able to really finish this write up...so their might be some errors**
Overall the install was pretty straight forward ONCE I got a factory wiring diagram. This setup has NO check valves, so longer starts are normal. I am pleased so far the results of this unit. I highly suggest this install is for someone with good electrical and mechanical skills.If there are any errors in the pictures I apologize in advance.
For the install, I took off my bed. 6 bolts, 2 hoses, 3 7mm screws for the filler neck, and 2 connections out back for the lights. Don't forget to unhook the battery first. The factory FPDM is out back and the tank is located driver side center of the truck.
Here you can see the attached Kenne Bell boost a pump wired into the FPDM. You will need to cut and splice into this connector later on.
Before you remove anything from the tank, blow it off with high compressed air.
Now you must remove the fuel lines and electrical connections. To remove lines, you must either press in completely, or pull out a tab then press in. **note** There is a line IN the tank you must unhook also.
Next you will need to take off the ring that holds the assembly in place. To do this you need a screwdriver and a hammer. Don't be afraid to use some force in this process.
[IMG][/IMG]
Now before you do anything else, blow off the area again of any loose dirt. You will need to disconnect one line that is inside the tank. Remove carefully. (sorry no picture)
You will need transfer the fuel level float sensor from your factory unit to the aftermarket Fore Precision Work's unit. This is a simple snap on, snap off operation. Disconnect the sensor's wire, DON'T CUT. Connect the wire from the factory level sensor to the wire on the aftermarket unit and use heat shrink to ensure a tight bond between the connection. You will also need to install your fuel pumps and hook them up to the existing wires on the unit. The pump wires will only go one way so it's dummy proof. Tighten hose clamps to the pump once they are installed in the unit. You must also attach a ground wire, just remove a screw and attach(see picture).
Now the unit is ready to install. When installing don't forget to hook up the in-tank line that you disconnected earlier.
You must also place the tab on the hat in the correct orientation. You will see an arrow on the tank(sorry no picture of arrow) Place the factory ring back on using a screwdriver and hammer.
Apparently, somewhere amongst the years, ford decided to change sizes of some lines. Included in the kit is an extra piece that allows you to use either of the lines. Remove the 2.5mm alan headed screws and replace. Snap your lines back on and you are finished with the physical install of the fuel hat setup itself.
**Note**This is where it will get real vague until I get some time to draw up a wiring diagram.
I installed the 2nd FPDM on the drive side frame rail near the factory FPDM. I drilled and tapped(6mm) the frame to use the supplied hardware. I also installed the two relays where the spare tires normally resides(mine has rides in my bed).
The two fuel pump 30amp breakers that come with the kit I mounted on the firewall with existing factory hardware. I made a small plate and bolted the breakers to it. I routed (2) 10 gauge wires from the batter to the bronze studs of the breakers. The supplied 10 gauge wire and looms travels from the "silver" stud of the breakers, through the cowl, down to the driver side frame rail to the back of the truck to the relays.
**continue on next post**
Old 08-23-2010
and just a picture of the fuel hat all wired up and complete..
Mosaleen Idler Installed
Old 08-23-2010
Meikol02's Avatar
Meikol02 Meikol02 is offline
Welcome to the forum.
Nice write up and pictures. Sorry you missed Jim Sr. but you are right about being hard to find time.
The guys at PSI are pretty cool to talk to I look forward to hearing the results of your set-up.
Michael
'07-0449
Old 08-23-2010
Welcome to the forums!
Old 11-17-2014
julioclotch julioclotch is offline
good job, I have a harley f150 sc and put mustang gt dual fuel pump kit, I think putting 5 speed manual transmicion t3640
