Old 12-10-2012
pine9280 pine9280 is offline
Default Headers install
I found this set of instructions for the set of headers i want to install on my Saleen. They are instructions for 99-04 Cobra and 03-04 Mach1 http://1.cdn.lib.americanmuscle.com/...04-install.pdf How much will these instructions differ for my Saleen or will they be pretty identical?
Thanks guys
1999 Saleen S281 SC
Old 12-10-2012
You can do it like that but you don't have to remove the K-member for the 2V. Just take off the two engine mount nuts and raise the engine. Unhook the steering knuckle so that it will slide between the tubes of the new header. You might want to take off the starter to give a little bit more room. Atleast this how I installed them on my 2V.
Old 01-02-2013
Was it a pretty big pain in the ***?
1999 Saleen S281 SC
Old 01-03-2013
Wireman's Avatar
Wireman Wireman is offline
Here is a write up i did during mine, hope it helps.
http://saleenforums.soec.org/showthr...ight=Long+tube
Last dyno put me at 394 / 405 after the header install and aluminum drive shaft.
03S281SC 03-269
Tunable induction CAI|2.8 pulley|39# Injectors|05 Mustang GT pump|90mm MAF|75MM BBK-TB|Mosaleen idler|MAC Long tube headers|Mac Off road X|LFP-H/E and tank|Chicane I/C|5gpm pump|373 FRPP gears|NT555R 305/35ZR1|MGW shifter|FRPP Alum driveshaft|N2MB two step
86-0087
03-269 S281SC
92 LX coupe
92 LX convertible
Old 01-03-2013
So you just jacked up the front and removed the engine mount bolts and jacked the engine up? Where did you jack the engine up from...oil pan? Also, you mention the starter but what other components did you remove for the install? Lastly, if you were to do it again would you remove the whole k-member?
Thanks for the feedback guys. Nice thread Wireman
1999 Saleen S281 SC
Old 01-30-2013
WildWillyWalker WildWillyWalker is offline
Here is my install:
http://www.cjponyparts.com/mustang-a...uctions/a/340/
It's a bit of a pain. It'd be a LOT easier if I had a lift.
Old 01-30-2013
saleensonoma saleensonoma is offline
modulars are a PITA when doing headers. The way codered mentioned it is how i do it. I have an engine lift so its easier for me to do it.
Saleen SC 89-0305
01 Bullitt #3251H/C/Turbo build
92 GMC Typhoon
89 Chevy S10 Cameo
07 Yamaha R1 Candy Red
Old 02-11-2013
99-0179's Avatar
99-0179 99-0179 is offline
Just plan on dropping K-Member, Supporting motor w/ a jack and adjusting up/down as necessary to get the headers in...
OH AND!.... don't cheap out on the gasket!
'99 S281 S/C 'Vert #179
Old 02-12-2013
Thats sounds scary!!
2002 Saleen Speedster #02-346
2007 Roush TrakPak-Race car
2015 Mustang GT
Email: sales@281m.com
Web: www.saleenspeedlab.com
CA's ONLY Authorized Speedlab Center
Old 02-12-2013
Werecow Werecow is offline
Supporting a motor on a jack can be dangerous, not to mention if you have a slip. what it could do to the motor. I had to do that once to replace an oil pump on the side of the road... I wouldn't suggest it.
Old 02-12-2013
Either way you do it you have to jack up the motor. Unless you get an engine lift. What is the best place to jack it up anyway?
1999 Saleen S281 SC
Old 02-15-2013
99-0179's Avatar
Ok what I DID which isn't the safest method, but I like to rely on my intellect when it comes to dangerous maneuvers.
Make sure you have a decent jack first off. I placed the jack straight in from the front of the car and supported the motor with a wooden block right under the harmonic balancer. Make sure you have the belt off. I was able to get all the up and down movement I needed.
Another safe measure would be to use jackstands as a backup placed on both sides of the oil pan in case it DID fall, you wouldnt be hammering the dents out of the oil pan.
| SOEC.ORG | ABOUT SOEC | MEMBERSHIP | MERCHANDISE | LITERATURE | VEHICLE PRODUCTION | SALEEN LOCATING SERVICE | SALEEN AUTOMOTIVE | CONTACT SOEC | SOEC @ FACEBOOK |
All Original Content Copyright © 1991-2017 Saleen Owners and Enthusiasts Club, LLC (SOEC). All Rights Reserved.
