The Saleen Forums at soec.org
Goodyear Mail-In Rebate
| SOEC HOME | MEMBERSHIP | SALEEN ALLEY | LITERATURE | VEHICLE PRODUCTION | WALLPAPERS | STORE | CONTACT SOEC | SMS SUPERCARS |
Go Back   The Saleen Forums at soec.org > Saleen Enthusiast Forums > TSBs, Install Manuals and Service Documents
TSBs, Install Manuals and Service Documents Technical Service Bulletins and other resources to help you keep your Saleen running in top form. Full access is available to forum registrants. If you can't find a document, please PM us or use the Contact Us form at the bottom of the page with year, model and concern.
Closed Thread
Old 04-21-2008
We've received a lot of questions by e-mail about the inspection and service of the twin-screw supercharger oil on late-model Saleens.
"The photo [below] shows the location of the fill plug on the supercharger," says Saleen engineer, Andrew Gardner. "The plug is removed, but the threaded hole is visible on the [center] side of the photo. Several components have been removed in this photograph to show the location, but it is straightforward to find. The oil should be replaced every 50,000 miles and it doesn't hurt to check more often. The plug is removed with an Allen wrench, and it can be done without removing any other components."
Billy Tally, Saleen's former chief officer of technology explained to us some time back that the 50,000-mile service interval is on the conservative side. The high-quality lubricant used from the factory doesn't need to be changed as often as engine oil, especially since there is no exposure to hydrocarbons or other contaminants. It's simply gears rotating, and the unit really doesn't get all that hot.
Many thanks to these gentleman for assisting us with this question, and owners should routinely inspect the oil level should something unforeseen happen -- better safe than sorry.
Old 04-21-2008
Default Series VI Supercharger Maintenance Manual
Saleen owners with this supercharger should consider keeping this download handy for maintenance and diagnosis -- at least you can be better informed should you take the vehicle in the dealer for service.
File Type: pdf SaleenSCMaintenanceManual-SeriesVIandTruck.pdf (454.4 KB, 80 views)
Old 06-08-2008
Default 2005-09 S-Series Mustang Reference Documents
2007 PJ Watts Link TSB -- if you bought a Saleen Watts Link setup for your Mustang, you may also be affected by this TSB.
Old 06-12-2008
Default 2005-09 Saleen Mustang Reference Documents
2005-2006 Saleen S281 Brake Line Recall on 14" and 15" Brake Upgrades
Old 06-12-2008
Default 2005 Saleen S281 Supercharged Hood Bolt TSB
Old 06-19-2008
Default 2005-2008 Saleen 475 HP Upgrade Install Manual
Old 06-19-2008
Default 2005-08 Saleen Series VI Supercharger Maintenance Manual - Mustang & F-150
2005-08 Saleen Series VI Supercharger Maintenance Manual - Mustang S281, S302 & F-150 S331
File Type: pdf 05-08 Series VI Maintenance Manual - Mustang & F-150.pdf (729.7 KB, 60 views)
Old 06-19-2008
Default Saleen SPEEDLAB Superchargers and Boost Gauge Statement
It has come to our attention at Saleen that there is some confusion with regards to how our supercharger works and what kind of boost pressure it should create. The following information should help you and yours assist customers with any questions they may have.
The first thing that has come to our attention is customers and dealerships saying, “the boost pressure gauge does not move no matter how fast I’m going.”
The only time the vehicle will produce boost is when the car is under load, meaning hard acceleration in 2nd or 3rd gear. You may see boost in all gears at wide-open throttle but, the amount of boost you will see will be small (2-3 lbs. In 1st, 4th and 5th gear compared to the 5-7 lbs you may see under hard acceleration in 2nd or 3rd gear). Extreme models should produce 10-12 lbs under load, depending on throttle input.
Our Speedlab supercharger works with a by-pass valve system similar to that of a 1993 Ford T-bird Supercoupe. When the air fuel mixture enters the inlet tube (the tube that connects the throttle body to the back of the supercharger) it has two routes it can take, either directly into the manifold or into the supercharger. When it gets routed to the supercharger the car makes boost. The way it gets routed to the supercharger is based on the by-pass valve and how much vacuum the car is making. When the car makes a lot of vacuum (hard acceleration) the butterfly that directs that air fuel mixture in the inlet tube closes and sends it to the supercharger thus, creating boost.
When the car is under normal driving conditions (even accelerating from a stand still to 80 mph) the butterfly in the inlet tube stays open, directing the air fuel mixture directly into the manifold thus, not making any boost.
Again the car has to be at wide-open throttle to produce boost.
PDF Download:
File Type: pdf SPEEDLAB SC AND BOOST GAUGE EXPLANATION.pdf (62.5 KB, 28 views)
Old 06-27-2008
Default 2005-08 Saleen Windshield Banner Installation
Old 07-02-2008
Default 2005-06 Knocking Noise from Front End
File Type: pdf STB06-009 front end knocking noise.pdf (144.9 KB, 67 views)
Old 12-29-2008
Default All Saleen Vehicles - Flat Spotting on Tires - STSB08-009
All Saleen Vehicles - Flat Spotting on Tires - STSB08-009 - December 1, 2008
SERVICE INFORMATION: Procedure to repair "flat spotting" on tires that have been sitting for a period of time.
IF YOU CONFIRM: The vehicle has a vibration while driving.
File Type: pdf Flat_Spotting_On_Tires_STSB08-009_SOEC.pdf (451.7 KB, 47 views)
Old 01-05-2009
2005-08 HID Mustang and S-Line Saleen Installation Manual PDF
Old 05-20-2009
2005-09 S-Series Body Kit Installation Manual.pdf
Old 05-20-2009
2005-09 Saleen Supercharger + Supershaker Upgrade Kit Installation Manual.pdf
Old 06-24-2009
If you have squeaky brakes, the cause may be an improper bed-in procedure and could be cured with a simple do-it-yourself fix.
Old 06-24-2009
2005-06 S281 Mustang Series VI Supercharger Belt Replacement
Old 08-02-2009
Saleen Center Exit Exhaust Installation (Revision B)
Old 08-04-2009
2005-08 Saleen Mustang Dual Fuel Pump Kit Install (should be applicable for 2009 as well).
File Type: pdf 2005-08_Saleen_Mustang_Dual_Fuel_Pump_Kit_Install.pdf (1.63 MB, 51 views)
Old 08-04-2009
2005 Saleen Mustang Fiberglass Hood Installation Manual (applicable for all years 2005-09)
Old 09-07-2009
2005-09 Saleen Mustang Gauge Pod Installation Manual - Boost and ACT
Old 10-05-2009
Default 2005-09 Saleen Mustang 6-Speed Transmission and Driveshaft Install Manual
Old 10-05-2009
Default Saleen Speedlab Series VI 2005-07 Mustang Kits
Saleen Series VI Supercharger Installation Manual
Closed Thread
All Original Content ©1991-2010, Saleen Owners and Enthusiasts Club - SOEC. All Rights Reserved.
