Go Back   The Saleen Forums at soec.org > Saleen Enthusiast Forums > Detailing
Detailing Interior & Exterior Car Care discussions sponsored by Mothers Polishes-Waxes-Cleaners.
Old 12-05-2018
FlyingSquirrel FlyingSquirrel is offline
Default How to Remove Mold from Your Car
We will describe the risks of mold exposure and the importance of preventing mold growth, while also providing a step-by-step guide on how to remove mold from your car. If youíre unlucky enough to already have developed this major problem, donít worry!
While it may seem like an insurmountable challenge, in fact with the right supplies and with some elbow grease you can restore your car to the safe, clean, comfortable vehicle you deserve.
I. What is mold, and Why is it Dangerous?
Mold is a type of fungus that typically forms in the presence of higher temperatures and high levels of moisture. Exposure to mold can cause major health issues, especially in those who are sensitive to it.
Those who are most susceptible to the effects of mold include those with lung diseases, allergy sufferers, and those with compromised immune systems (e.g. those receiving treatment for cancer, who have had an organ transplant, or who are taking immunosuppressive medications).
The presence of mold can lead to respiratory and skin irritation, lung infections, asthma, and other health challenges. Symptoms can include nasal congestion, wheezing, eye and skin irritation, fever, and shortness of breath. Thatís why itís extremely important to avoid exposing yourself to mold, especially somewhere youíre likely to spend as much time as your car. (And to make sure you never leave your car out in the open if the top is down!)
Luckily, if you notice moldótypically noticeable due to a strong odor, but also potentially visible patches of moldóthere are steps you can take to fix the problem. Keep reading to learn how to protect yourself from mold in your automobile.
II. How to Remove Mold
There are, of course, numerous methods to eradicate mold from your car, and everyone will recommend something different. But hereís what we think is the best way to do it.
1. Protect yourself
Always make SURE that you are wearing a surgical face mask or particle mask as well as strong, non-porous household cleaning gloves (make sure theyíre solid enough not to break). This will decrease the likelihood of harmful, excessive exposure to mold and its possible toxins.
2. Air out your car in a sunny spot
Sunlight and fresh air are pretty powerful tools in the fight against mold. Like virtually all types of fungi, mold grows in moist areas, so the combination of sun and fresh air dries things out and makes it impossible for mold to survive.
Ideally, on a clear day, move your car to a sunny parking spot and open up the doors and windows (and sunroof, if there is one). Give it a few hours and let any dampness dry out. (Just be sure to keep an eye on the weatheróyouíll be giving yourself even more of a problem if a sudden shower appears and your carís interior is exposed to the elements!)
3. Inspect your car
Itís a good idea to look all throughout your car to get a sense of where the mold is an issue, so you can focus on particular areas in the later steps. Make sure to look at the following: surface of the seats, underneath seats, steering wheel, floor, seat belts, and seat side seams.
Mold can vary in color, so just look for (typically circular) areas of black, green, white, gray, or brown. Thatís how youíll know where you need to focus your cleaning efforts.
4. Prepare before disinfecting
Try to break up patches of mold by gently brushing them with a toothbrush. Then, if youíre lucky enough to have access to one, use a wet-dry vacuum cleaner to vacuum up the mold youíve just brushed up. (If you canít get your hands on a wet-dry vacuum, thatís OKóthis step is helpful but not essential).
5. Spray with disinfectant solutions
Take out your carís seat covers and carpets. Before you wash them, you can use any of the following mixtures to kill mold in these sections of fabric:
  • 4 parts white vinegar and 1 part water
    1 quart of water, Ĺ cup of white vinegar, ľ teaspoon of clove oil, and 1 tbsp of baking soda (note: avoid exposing skin directly to clove oilóit can cause dermatitis and irritate skin and mucous membranes)
Pour either of these mixtures into a spray bottle and spray it on your carís seat covers and carpets. They should sit on the material for at least 20 minutesóor even longeróin order to ensure that the potent ingredients are able to fully kill the mold and prevent its regrowth.
You may also want to spray other parts of your car where mold has been able to infiltrate and cause odor (including as the dashboard, air vent, steering wheel, and seats).
Stains on the seats, seat covers, and carpets can be removed by sprinkling good old Borax powder on them (yes, itís useful for so many purposes!), waiting at least 10 minutes, and then sweeping or vacuuming the powder away.
6. Remove the leftover residue
Once the mold has been killed, you can use a wet-dry vacuum to vacuum up the liquid solution. Otherwise, you can wait for the areas to dry and then use a regular vacuum to vacuum up the dried-up mold residue. If you use a regular vacuum, make sure you use one with a bag and then throw the bag away afterward. Otherwise, youíll be spreading mold spores when you bring it inside to clean your home.
7. Wash your carís seat covers and carpets
Now that youíve thoroughly disinfected them, you can use standard detergent to wash your carís seat covers and carpets. If possible, add Borax powder when you wash them and allow them to dry in the sun if itís a sunny day (as we said, the sun is incredibly helpful for this process).
If for whatever reason you canít wash them with detergent, an alternative is to spray them thoroughly (really all over, so that the mold spores are killed) with a solution of water and non-iodized salt. Then allow them to dry in the sun, and wait for the salt to form a crust on the surface, which you can brush or vacuum off.
Salt does a great job getting rid of moldóit dries it out thoroughly and kills it.
8. Optional: use an air freshener spray to remove leftover odors
If youíre bothered by the residual smell of vinegar (which will disappear as the liquid completely evaporates), you can use an air freshener spray to ensure everything smells fine.
Most important is to air everything outóthatís what will leave everything smelling good.
9. Replace the seat covers and carpets, and keep the mold from coming back
Once youíve washed and dried the seat covers and carpets, itís time to put them back in your car.
And hereís a key takeaway: since mold requires a wet environment to grow, you can prevent its return by ensuring your car is dry and that it remains totally dry. This is the most important part of preventing mold re-growth.
You can use a dehumidifier to lower the overall moisture levels in your car.
Now you know that, as worrisome or even scary as the prospect of a mold-infested vehicle can be, there are options to address the problem. All it takes is some time and effort, with attention to safety (wear a mask and gloves!) and your vehicle can be good as new.
You can even use natural products like vinegar and clove oil solutions to do the work for you, if thatís a priority. And once youíre done, of course itís important to keep your car dry, so that you donít have to go through the trouble of cleaning out the mold again in the future.
When you buy one Valeoģ ULTIMATEô Wiper Blade from Tire Rack, you'll get one free!
All Original Content Copyright © 1991-2019 Saleen Owners and Enthusiasts Club, LLC (SOEC). All Rights Reserved.
