Sorry, Couldn't change the title, looking to see if anyone has replace their oil pan gasket? I have a leak, I need to do it to mine but don't know where to start . Maybe just the gasket?
Thanx Joe Last edited by Jo-Jo; 03-17-2021 at 12:13 AM. |
Do you have oil leaking from the gasket, or is rear main seal leaking?
It's from both.
Well you wont want to read this. rear main, you have to pull the transmission, clutch, and flywheel to get to it. Oil pan gasket, the oil pan strattles the K member, and wont drop enough to get the gasket around the oil pump pick up tube. You have to raise the engine. Hit you tube, lots of different ideas and tricks to avoid pulling the engine. When you have the pan off, and at the rear main, do a redi sleeve too on the crank, so greatly decrease the probability of the rear main leaking again.
