Old 04-27-2010
03SaleenSC 03SaleenSC is offline
Exclamation Help: Saleen Intercooler/Heat Exchanger Pump - Replacement?
The stock Saleen Intercooler/heat exchanger pump is leaking on my 2003 Supercharged Saleen......What are my options for replacement or repair??
I cant seem to find any good information online anywhere....
Old 04-27-2010
02saleen's Avatar
02saleen 02saleen is offline
http://saleenforums.soec.org/showthr...tercooler+pump
hope this helps
Old 04-27-2010
Yes, thanks for that, I did see that thread actually but I wasnt sure what to make of it since no one here has actually tried the pump to see if it actually works, or even mounts up, but there was some promising information in there.
If that stock pump flow number is accurate then these cars have very small pumps...1.5 GPM seems a lot lower than other pumps I have seen on the cobra and the lightning trucks, so I wasnt sure if that was accurate either, but I have no idea personally.
If that pump does actually work then that would be AWESOMEEE to say the least
I was a little worried that the Shurflo pump may not be strong enough because I tried to find some information on the stock Oberdorfer 170M-A95S pump that I took off my car and there wasnt much information about it when I googled it but I did possible see something about the pump being capable of 12GPM and also saw stock cobras and lightnings pumps stating that they had a flow of 8GPM which made me not so sure that the stated stock 1.5GPM on the Saleen seem very low, but again info is very hard to find online about these pumps so I am trying to piece together any information that I can
Old 04-27-2010
02saleen's Avatar
I am not so sure either but I would expect it to be a little smaller than a cobra lightning ones. If I remember correctly they are both M112s at least a cobra is and we have an M90 a little smaller so a smaller pump would not surprise me
I don't know much but now that I have a supercharger I try to get info like crazy for when something does go wrong
Old 04-28-2010
SonicBlue's Avatar
SonicBlue SonicBlue is offline
Somebody just needs to try that new pump and let us know how it goes!
I only know one person who has done it (the guy who told me abou tit) and he has had great results......
SOmeone ON THIS FORUM should try it. I woudl but It;s a tad hard to install it from IRAQ ;)
let us know!
'03 SC Coupe (1 of 2) 380hp / 400tq @ 12lbs boost 18x10" rear wheel option
13" Saleen Brakes ◄ Chicane Intercooler ◄ 2.875" VI Xtreme Pulley ◄ 4" polished CAI
75mm TB ◄ Bassani Exhaust (Mid Length Headers, X-Pipe, Mufflers) ◄ FRPP 3.73 gears
90mm MAF/42lb Inj ◄ Ford GT Fuel Pump ◄ Rear LCA's ◄ Subframe Connectors + more!
Old 04-28-2010
Same here, thats a good point. I just have no idea either, I was hoping someone had some experience with this or has done it before and could chime in....Thanks for the info either way.
Old 04-28-2010
let us know!
ahahah yea being in Iraq sounds like it might make things a little difficult. I may have to give it a shot, I just want to make sure I explore all available options before I pick something
Old 05-23-2010
m260gt m260gt is offline
let us know!
pretty sure i bought the blower from the guy that told you about it. mike correct? anyways. I have the surflo pump in mine and it worked for a few days but now doesnt work anymore. i believe its an electrical problem since im no electrician but i will get it hooked up right and let everyone know. the guy i bought it from says it worked great.
Old 05-28-2010
We run a Meziere that is 55gpm.
Old 05-29-2010
SonicBlue's Avatar
I see a few of them on thier website....which one was it that you used!?
Old 05-29-2010
muzzy muzzy is offline
That aftermarket pump sounds great. I would have tried one but I just replaced mine. Same problem, “leaking” I called Saleen and they said it was a common problem. I ordered mine from Saleen and paid for the Saleen name as well as the pump around 300 bucks with shipping. If I were you I would try the aftermarket pump and save myself about 200 dollars and maybe even get a better pump at the same time.
Muzzy 2004 281SC convertible #355
42#
JLT cold air
JDM SCT 93 oct tune
90mm maf
75mm TB
Ported and Polished SC by PSE
Mosaleen pulley sys
Gaterback belt
NGK tr6 @034
2.9 pulley
Chicane SS braded IC lines
SS Rear bumper inlays
Carbon fiber dash kit and shift knob
1 bottle of water wetter
Old 05-29-2010
There is a few different options depending on what you have. If you want one, we'll spec it out to your cars needs.
Old 06-02-2010
Wireman's Avatar
Wireman Wireman is offline
let us know!
I finally got around to ordering it and just got mine yesterday and hopefully have time to swap it this weekend. I will keep you posted on this thread. My only real concern is longevity, there is no "duty rating" on the shurflo pump/motor. The factory pump is more than likely designed for continuos duty, where this one was made for intermitant use in a marine app like a bilge pump.
BTW, with my cooling mods i still see 130 temps max now on a super hot day. That after flogging it repeatedly!
03S281SC 03-269
Tunable induction CAI|2.8 pulley|39# Injectors|05 Mustang GT pump|90mm MAF|75MM BBK-TB|Mosaleen idler|MAC Long tube headers|Mac Off road X|LFP-H/E and tank|Chicane I/C|5gpm pump|373 FRPP gears|NT555R 305/35ZR1|MGW shifter|FRPP Alum driveshaft|N2MB two step
86-0087
03-269 S281SC
92 LX coupe
92 LX convertible
Old 06-03-2010
SonicBlue's Avatar
Great keep us informed....looking forward to hearing the results!
HOPEFULLY the temps go down for you too.....it's suprising to hear that your still getting 130deg temps after the Chicane IC mod.
But I guess you did say that is after "flogging it"
Old 06-09-2010
02S281SC's Avatar
02S281SC 02S281SC is offline
why wouldnt you guys buy the ford racing 03 cobra pump from yates performance for 114? it flows 5 gpm and is not much more than the marine pump. here is a link http://www.yatesperformance.com/en6400.html
2002 S281 SC #243
1986 saleen #174
2002 harley davidson SC f-150
2000 lincoln LS
1984 SVO mustang
1984 comp pep SVO mustang
Old 06-09-2010
Wireman's Avatar
The reason i didnt use this or the lighting pump is the location of the suction and discharge. The shurflo pump needs no additional fittings and the bolt pattern is supposedly the same. I haven't had time to install it, but i will keep you posted.
03S281SC 03-269
86-0087
03-269 S281SC
92 LX coupe
92 LX convertible
Old 06-12-2010
apicia apicia is offline
How was the install? I heard the Lightning pump (used on 03/04 Cobra upgrade) is not a plug and play for us.
Old 06-13-2010
Noish01 Noish01 is offline
Glad somebody brought up the Cobra pump, I was wondering the exact same thing. I can't wait until somebody gives the result of the pump as my Saleen is my DD so I can't really chance testing a pump
Old 06-14-2010
Wireman's Avatar
Default Results
I finished the install last night and took it for a cruise. Here are the results.
Pro's
-Same exact bolt pattern
-It runs quieter w/ no vibration at all (due to rubber mounts on pump).
-Noticeable increase in flow (looking in the tank).
-Self priming (sweet!). Didn't have to burp the pump.
-Temps are 10 to 15 deg cooler while cruising and seemed to recover quicker after boosted runs.
Con's
-different location for the inlet (suction) on the pump. The lightning pump would be the same as the OE pump.
-required additional jam nut fittings. Not a big deal found them at Home Depot for around $2.50 each.
-required rerouting the line from the tank to gain enough hose to reach the pump. Not a big deal. Looks good.
Summary
-The ambient air temps while testing were only 70 deg. A 100 deg day will show if there are any noticable gains. The install was easy and it quiets up the pump quite a bit. The Lightning pump would be a closer match for the lines, but may still require additional fittings. This mod would probably do more for someone w/o the Chicane I/C upgrade. Hope this helps...
Scott
03S281SC 03-269
86-0087
03-269 S281SC
92 LX coupe
92 LX convertible
Old 06-26-2010
Wireman's Avatar
Update:
95 deg temps so i gave it another try and there were no noticable change towards cooler intake temps.
The best test for this is to do a couple boosted runs, then park it and shut it off, this will heat soak the intercooler and intake manifold. I saw 180 degrees at start up and it cooled down to the normal 125-130 degrees i see since the chicane I/C swap. It may help cool it a little faster, but not that i could notice.
I dont think the pump swap is worth while if you have the upgraded I/C.
I call "not it" on the next guinea pig test....
03S281SC 03-269
86-0087
03-269 S281SC
92 LX coupe
92 LX convertible
Old 06-26-2010
SonicBlue's Avatar
NICE! Good review and glad someone actually treid it!
I like the Guinea pig comment! haha
Old 07-17-2010
metatrox metatrox is offline
I too just started having a leaking pump this week. It is the Oberdorfer 170m a95s Is this the stock one? Because it appears the wires have been spliced a couple times.
Looks ike I need to get a new one. Which one should i go with?
Old 07-18-2010
FinnSaleen FinnSaleen is offline
The original pump is very easy to dismantle and repair. There is only one shaft seal that can leak. Did that on mine about a year ago and it has been fine since.
Old 07-18-2010
I'm assuming you just ordered the seal from them? Price? How do you get the seal out? And back in? Their maintenance PDF isn't working.
Old 07-19-2010
I got the seal from a local hydraulic & pneumtaic store, it's a standard seal so they can get you a correct seal by measuring the old onel.
Don't have any specific instructions or pictures but it's quite obvious if you are used to work with simple hand tools
Old 07-19-2010
I live in a small town in new Mexico. No store like that around here. Lol I called oberdorfer and they said like 32$ but have to order from distributor and thu recommended some place in Florida. LoL
Old 04-05-2011
02S281SC's Avatar
holy thread revival!!! any updates on how the pump is working out. has it quit yet? and do you have any pics of your install
2002 S281 SC #243
1986 saleen #174
2000 lincoln LS
1984 SVO mustang
Old 04-05-2011
Wireman's Avatar
Pump is working fine, but i don't drive the care much. Sorry, no pics...
03S281SC 03-269
86-0087
03-269 S281SC
92 LX coupe
92 LX convertible
Old 09-09-2011
kevinrocksman kevinrocksman is offline
Default hm
sorry you all. I know its been over a year since anyones posted butthe 03 cobra pump and it keeps stopping the flow. It pumps fine some days but some days it doesnt seem like its pumping hard enough. I know the pump is working but the liquids not flowing..
Old 09-09-2011
We have the perfect replacement pump, and its cheaper than the factory Bosch pump. Just tell me what size hoses your running whether its AN fittings or barbed and we'll configure it for you!
Old 03-22-2012
02GT 02GT is offline
Read my message above, I accidentally submitted this to early...
Old 03-22-2012
Your pump could possibly need only a new viton lip seal. The lip seal part number is 9986, list price around $34.00. The rebuild kit, part 10912, includes an impeller, lip seal, and gasket has a list price of around $95.00. A new pump and motor, part number 170MS5-A81, price is around $419.00. The A81 motor is 1/10 hp, 3480 rpm, and 12 volts DC. The old N95 motor was 1/13 hp, 3160 rpm and 12 volts DC.
Contact Vissers @ http://www.visserssales.com/. Mine is leaking too and am in the process of getting a "Lip Seal" from them as I got the above info through another contact.
Better to fix the pump if you can than to replace it as it costs a lot of money.
You can also try contacting Halsted Hogan at (213) 623-1248 for the parts, they may have them as well.
In Canada, you can call Motion Canada at (604) 623-1793.
If anyone wants the schematic for the pump that saleen includes in their kits, send me a private message (not sure if you can post PDF's or how here yet, am new so bare with me)
Old 04-27-2012
Default Order replacement parts from here
I got my 10912 repair kit just the other day, these guys below were very helpful.
SEE BELOW:
170M-S5-A95 is Made by Oberdorfer Pumps, we do carry parts for that.
170M-S5-A95 (170M) = bronze centrifugal pump 3/4" npt ports, (S5) = viton lip seal over 300~F temp., (A95) = 1/10hp 12 volt motor.
http://www.oberdorfer-pumps.com/Spec_sheets/170m.pdf
10912 repair kit, incl. impeller, seal and gasket. $113.05 net price, approx. 2 weeks delivery
7020 gasket $13.28 net, in stock
9986 viton lip seal....use part# 926050V $16.20 net, in stock
(fits little giant, oberdorfer, hypro)
Here is the contact I spoke with:
Dean Tischer
Renown Industries
5608 - 94a street
Edmonton, Ab
http://www.renownindustries.com/
Old 04-27-2012
02S281SC's Avatar
I used a cobra pump and 10 dollars worth of adapters to make the threaded lines work with the clamp style flange on the cobra pump. Also a fuel injector connector is the pigtail you need for it as well. Mine works awesome. I have around 65 bucks in the setup.
2002 S281 SC #243
1986 saleen #174
2000 lincoln LS
1984 SVO mustang
Old 10-14-2013
s302yl20's Avatar
s302yl20 s302yl20 is offline
this is NOT a direct bolt nor a plug and play but here is some info to help you out
Get the Cobra 03 04 intercooler pump, American Muscle had it for like $139
then you will need to call a Bosch dealer in your area and get Bosch #1287013003 - which is the pigtail ( works PERFECT and only cost $11 ) - we had to use some reducers that we got at Home Depot, very cheap, we did a little rerouting of the hoses so there was no "crimping" - ( notes: the inlet and outlet of the Cobra pump is NOT the same as what comes on the Saleen keep that in mind when doing the install ) and there ya go
2014 S302YL #20
2002 S281SC #64*
1996 S281 #220*
*sold cars*
Old 08-06-2014
Saleenaddict87 Saleenaddict87 is offline
So I got the shurflo pump, installed it, and I have no circulation, wtf?? Everything's connected what's the deal?
04-192 screaming yellow s/c
89 ssc 079
july 2012 MM&FF feature cars
Old 08-06-2014
Did you purge the lines? Did you power it up on the bench to make sure it worked and nothing was lodged inside?
Old 08-06-2014
Lines were clear, how do I power it up?
89 ssc 079
Old 08-06-2014
Find a 12v power supply and connect the leads.
Old 08-15-2014
found the problem, just a bad positive connection, Shurflo pump works good, I like how it uses the existing mounting holes, good amount of movement in the reservior, had to get new lines to reach the inlet/outlet ports, but no big deal
heres the problem, I took the car for a ride, about a half hour of alternating high rpm and cruising, my air temp gauge isnt pinned anymore, but its not much lower, still around 180-190, whats my next course of action?
89 ssc 079
Old 08-15-2014
SyberSaint's Avatar
SyberSaint SyberSaint is offline
21st century intercooler and Heat exchanger.
Syber
Old 08-15-2014
Your next step is to verify your water temps are relatable to your IAT. Call me if you need help with this.
