Lower S331?
I understand that the S331 comes with racecraft front springs and racecraft struts. However, I am on a quest to drop the s331 a tad lower. Not slammed, just a hair lower...maybe a 1/2 or 2/3 drop.
I am sure that I can lower the rear with some simple lowering shackles. The front, however, I am not so sure about. Does anyone know if there is a spring isolator that I can remove. Many times, that will give a 1" drop. If not, does anyone know how much the racecraft spring actually lowers the truck? If I know that, I will know what other spring I can buy to drop it lower. IIRC, the S331 sits an inch higher than a stock F150 due to the 23" wheels, even with the racecraft suspension. Thanks. |
Are you sure about the ride height.....? Even with the 23" wheels the tire profile is 40 and the overall tire / wheel height should be very close to the stock package. My clone S331 is a 4x4, with the lowering kit installed and the 23" wheels it's much lower than stock.
When I was researching these trucks before I bought them, I read that in an online magazine article. I will be darned if I can find the article again though.
