Old 11-20-2012
07s281sc's Avatar
07s281sc 07s281sc is offline
Default Q: Priming Intercooler Pump?
Noticed some higher than normal IATs recently. My intercooler pump is not circulating. Timer box is clicking after 30 secs key on engine off but no pump engagement. The IC fluid was recently changed for service and I suspect it may be a priming issue. Is there an easy way to prime the ic pump? Thanks
2007 S281sc-437 Rwhp/433 Torque
Saleen SuperShaker w/ 3.6 pulley and custom tune, Magnaflow X pipe w/cats, Corsa Mufflers, BMR Lcas, GT500 fuel pumps, AFCO Heat Exchanger, Chin spoiler, Saleen lower mesh grill, MGW shifter, 2010 Saleen shift knob, UPR Catch Can, UPR Tensioner, V10 Water Pump Pulley, LED Lighting, HIDs
Old 11-20-2012
redruder's Avatar
redruder redruder is offline
I just disconnected my upper hose that runs to the blower and used my garden hose with a spray nozzle to shot water into the system. Worked like a charm.
http://i1278.photobucket.com/albums/...der/4-Copy.jpgS281-E #06-0036
Best daily driver ever.
Old 11-20-2012
Char259 Char259 is offline
i had a plastic lid from a ziptie container, drilled a small hole in middle and placed it over the intercooler reservoir. Turn air compressor way down and pumped air through the hole, you hear bubbles in the heatexchanger, within a minute it will start flowing normally
[SIGPIC][/SIGPIC]
13 Boss Laguna Seca #738
05 s281 #1401~ Sold
Old 11-21-2012
OneQwkStang's Avatar
I have a Meziere pump, just turned it on....topped up res after it went down a bit.
Old 11-23-2012
07s281sc's Avatar
Tried priming the pump a couple different ways without luck, I think the pump is dead. I found a new one for $85.00. Seems like a pretty good deal with free shipping.
http://www.yatesperformance.com/en6400.html
Old 11-23-2012
If the pumps not running it could be the relay, they tend to fail, or the inline fuse.
Old 11-23-2012
I'd spend the extra bucks and get this....considering you already have the better HE. Why not flow more coolant through and bring the IAT down.
http://www.amazon.com/Meziere-WP136S...ere+water+pump
Old 11-23-2012
redruder's Avatar
I would have to agree on this. The stock pump doesn't really pump enough to keep up with the heat these blowers produce. I would get a larger capacity resivoir as well if you don't already have one.
Old 11-23-2012
07s281sc's Avatar
Fuse is good and I have the JDM intercooler relay with optional on/off switch on the way. My IAT's with the stock pump and AFCO non-fanned HE barely registered on the temp gauge so for now I think the stock pump will be fine although if I decide to start open tracking again that may change. =)
Thanks for all the valuable input.
Old 11-25-2012
MOUNT-N-SLOT's Avatar
MOUNT-N-SLOT MOUNT-N-SLOT is offline
Question. My pump runs. How "Vigorous" should the coolant in the reserve be agitating? It's moving, but how much is normal. Can someone post a video?
Reason I ask is I'm not sure the coolant is circulating through the system.
620HP ROCKS!
2007 S281 Extreme #074
Founder / Managing Partner:
www.IMPACTWEAPONSCOMPONENTS.com
http://www.facebook.com/ImpactWeaponsComponentsLLC
Old 11-25-2012
you should see a good amount of agitation, ill post something later if I get a chance. But a look into the reservior should see fluid moving out pretty good
[SIGPIC][/SIGPIC]
05 s281 #1401~ Sold
Old 11-25-2012
redruder's Avatar
If you turn the ignition on but not the car and pop your hood you should be able to hear the coolant flowing. Thats with the stock pump and its even more noticable with one of the higher volume pumps. My stock one ate it about 6 months ago so they do seem to be the week link in the system, everything eles is undersized for anything but the lower boost levels.
Old 11-25-2012
07s281sc's Avatar
I can try to take a video when I install the new pump. Btw- got any deals on 30 round Magpuls right now?
Old 12-03-2012
07s281sc's Avatar
Replaced the pump today. After installation I could hear the pump turn on but was not priming from the air trapped in the system. Disconnected the upper reservoir line and capped it with duct tape. Forced some low pressure air through the top of the reservoir and started circulating again. IATs below 100 now.
Old 12-09-2012
07s281sc's Avatar
Key on engine off flow from the stock intercooler pump into the stock saleen intercooler resevior. On my car I am running the Afco non-fanned HE
http://static.photobucket.com/player.../VIDEO0027.mp4
