Saleen Supershaker TMAP Sensor Wiring
A question for Saleen Supershaker owners.
The TMAP sensor is a 4 pin sensor. The Saleen Supershaker Instruction Manual says 5 pin but the TMAP Sensor is actually a 4 pin sensor. 1. The original Supershaker TMAP sensor part number is 2R3A-9F479-AA. Is there a superseded part number if I need to replace the TMAP sensor? Yes, I can also check with the Ford dealer. 2. The 4 pin TMAP sensor utilizes only the two wires, the grey wire and the grey w/red stripe wire in the TMAP sensor female connector/pigtail. The two brown wires in the female connector are not used but are tucked into the plastic convolute. Question. Which of the 4 pins in the TMAP sensor is the designated pin for the grey wire and which is the designated pin for the grey/red stripe wire? Orientation should be noted with the TMAP sensor installed on the Supershaker flat plate. For example; aft pin, fwd pin etc. If I had the original TMAP sensor and female connector I would not need to ask this basic Supershaker wiring question. Last edited by jrcalvin; 01-08-2021 at 03:02 PM. Reason: spelling |
Took a look at mine, 1st pin is grey red, 2nd pin is grey. Going from front of the engine to back.
Supershaker TMAP wiring
Thank you Tbar for taking the time to check out the wiring. I recently acquired a used Supershaker Kit and the Kit had the TMAP sensor installed but did not have the female Connector for the TMAP sensor so the grey and grey/red wires location to the TMAP were an unknown.
No problem.
