1999-2004 Saleen Mustang For the SN-95 New Edge platform. Be sure to specify year, model and equipment if asking for help. |
Sail panel warped
i was washing, waxing my saleen today and noticed rite about the back windshield where the sail panel meets it theres a gap and its not sitting flush with the roof line. its not coming off alot but enough to where i can notice it and or if your looking. so i took off the interior panel on the inside to see if a bolt was loose and nope. so ive come to the conclution im gonna have to use some double sided tape. its dosent take much pressure to hold it down flush..but then again all im wanting is a tape to seal off the gap, anything thats help holds it down is a plus, cause really i dont want water to be getting down there.
ive got some pics ill upload later but what kind of double sided tape or really anything should i use to hold it down? thanks
Bullitt manifold swap, longtubes, off road x pipe,borla atak, mgw short throw, 3.73 gears, h&r super sport springs #00-484 Nick |
Pics would be helpful.
2002 S/C Saleen Coupe Torch Red #293 21st Century Heat Exchanger 21st Century Intercooler Brembo Brakes Corbeau Seats |
Good luck. I had a set of 2 piece panels and they were warped real bad.
1996 #222 1 of 21 in Moonlight Blue 1 of 8 with exact options 3:55's F-Leather 2 Point Chassis Brace 2000 #944 Performance Red 3:08's Chrome wheels, Supercharged, Floormats. 2002 #48 Mineral Gray Extreme |
its crazy, i was just like what! the rust luckily was just on the surface and was able wipe off....it dosent take much pressure to hold it down, i found some industrial sided tape and tested out using an old exhaust hanger and a can and held great, pulling force it would not come off, i had to tear off at an angle so my give it a try and double it up or so just help fill gap and also not as much stress
Wow I have never seen anything like that. So it is staying put right now?
Is that rust there, or the old tape? If that is rust starting, I would deal with that before reattaching it properly.
instead of double sided tape i used an expanding foam strip we use on barn roofs/tin roofs to keep dirt, bugs or whatever out of gaps and expands up to 1/2. as tight as the gap was the foam is staying very tight heres the outcome
me either, its strange...if your looking at the panel you would never tell. i was just waxing the top and i was wiping it off i saw it. totally blew me away and was really disappointed when i saw it lol ive never noticed and have owned it since feb.
