  #101
Old 11-14-2011
Gray is Grey's Avatar
Gray is Grey Gray is Grey is offline
Well that is awesome then, I used to love WOT shifting in my 87 5.0. That is until I blew out my rearend. Then a week after being back on the road my tranny went out under normal driving. I wish they would have had the WOT box back in the 80's.
If you were to run cats, would it be better to go with metal core?
05-653 Mineral Grey
Brenspeed Stage 3 / Aluminum hood / Shaved antenna / This,that and the other.
  #102
Old 11-14-2011
I haven't done a lot of research on that, but I would suspect metal core would be the way to go.
  #103
Old 11-15-2011
Char259 Char259 is offline
Interested in this thread, No emissions here so the CATS went right after I got the car, for off-road x-pipe.
Questions
1- With the throttle staying down and after the clutch blip does it want to get out of hand when it cuts back on. Being in boost I can see it trying to getaway when it comes back?
2- the clutch blip is just to activate the box, I think im missing something. I thought the idea was to avoid the lag in depressing the clutch and working it into gear?
[SIGPIC][/SIGPIC]
13 Boss Laguna Seca #738
05 s281 #1401~ Sold
  #104
Old 11-15-2011
Questions
1- no, it is more civilized than if you did a true no lift shift. I think it is that way since I have it in AUTO mode and it doesn't turn the ignition back on until you let off the clutch or 350ms. I also think that since it cuts the ignition and you aren't continuing to increase rpms that it isn't as harsh. It really feels like an automatic transmission when you get a real firm shift. I haven't been able to do any 1 to 2 shifts since I can't wot 1st on the street.
2- the box looks at throttle position and clutch pedal position. When it senses you are at wot, and depress the clutch, it cuts the ignition for a brief moment allowing you to shift. After that, it kicks everything back on.
  #105
Old 11-15-2011
Ice Sterling#15's Avatar
Ice Sterling#15 Ice Sterling#15 is offline
I took my Sterling to the track this summer and on my 3rd run I made a 10.84 @ 132MPH, 1,644 60 ft
Hilmar Jacobsen,
Saleen Sterling #15 10.847@132 MPH,
Saleen 2006 #1116 10.22@133 MPH
1966 Mustang Coupe
Reykjavik Iceland
  #106
Old 11-15-2011
OneQwkStang's Avatar
What do you have done to that thing?
  #107
Old 11-15-2011
Yeah, thats a great time! I must know what you did to that car.
  #108
Old 11-15-2011
I wanted to put an update on the wot box. Just got a code tonight that I was lean. Talked to wot box manufacturer and they said the unburnt fuel could cause the code to show up, but it wasn't going lean. Still loving it!
  #109
Old 11-16-2011
I haven´t done much to the car. I put in some KOOKS headers, Ford Rasing throttle boddy, 60bl injectors, 12% overdrive crank pulley and a one pice aluminium driveshaft with MT 295/45/17 drag radials for the track. I´m sure if I had done more runs I would have got better time because I was just feeling how the traction was and did not start the run on full power. In my 4th run the belt broke. It was a Gates belt that I was not satisfied with. But now I have the same belt as came on the car. Much better.
Hilmar Jacobsen,
1966 Mustang Coupe
Reykjavik Iceland
  #110
Old 11-16-2011
Saleen S281 Saleen S281 is offline
Thats freakishly fast times for the mods, is it an extreme? How much boost? Nice times!
  #111
Old 11-16-2011
This is the 25 Anniversary Sterling (Extreme) 15/25. It boosts 14 and after this mods it´s around 700HP. It was 620 HP from Saleen
Hilmar Jacobsen,
1966 Mustang Coupe
Reykjavik Iceland
  #112
Old 11-16-2011
That sounds about right then, @600whp. That's awesome, congrats!
  #113
Old 11-16-2011
My guess is you will just have to watch the condition of your spark plugs more often. We recomend changing plugs on S/C cars every 18k miles or 18 months. You will have to reduct that depending on usuage.
  #114
Old 11-16-2011
Originally Posted by saleen s281 View Post
that sounds about right then, @600whp. That's awesome, congrats!
nice signature image!!!
  #115
Old 11-21-2011
Thanks! I think it would of looked better smoking the tires on this pic, nice shot!
  #116
Old 11-21-2011
Update appreciated!
05-653 Mineral Grey
  #117
Old 11-21-2011
Haven't had much time to mess with it lately, but I have been getting lean codes on one or both banks almost daily. I am sure it isn't truly lean, but I need to figure out why it is happening. I am going to pull the plugs and look at them as Jason mentioned and I am also going to disconnect the WOT box to see if they stop. I am just driving the car back and forth to work right now so I am not using the WOT box functionality.
  #118
Old 11-21-2011
wiggywigton's Avatar
Have you recently installed a new tune? Might want to check to see if there is an issue with your tune...
Mike Wigton
#06-409
  #119
Old 11-21-2011
No, haven't touched the tune.
  #120
Old 11-22-2011
I remember Brenspeed asking me if I was going to keep my O2 sensors before they completed my tune.
I looked a bit and found out you can have the rear O2 sensors deleted with a tune.
Since the WOT box shuts off the ignition and dumps extra fuel, is it possible your cats are already failing and the rear O2 sensors are unable to get an accurate reading? Or is it possible the fuel dump has fouled the front sensors?
I am just shooting thoughts, feel free to correct the ignorant.
05-653 Mineral Grey
  #121
Old 11-22-2011
I would say that any of those scenarios sound reasonable.
  #122
Old 11-22-2011
You don't drive WOT to work?
  #123
Old 12-01-2011
Ok, got an update on my lean issue. Long story short it ended up being a cracked oil separator line. I was sure it had to be the wot box since it happened right after my install, but it wasn't. I will be performing Barricade's fix shortly.
  #124
Old 01-25-2012
Any new runs guys? Nice and cool weather makes good times! Im still working on my turbo install, had to recover from xmas and my wifes surgery (not that kind, lol).
  #125
Old 01-26-2012
everything has been shut down here for a while. Waiting on spring. Any Marylanders or Virginians, MIR has a track rental on April 6th. Currently I think 15 cars are set. If interested let me know
[SIGPIC][/SIGPIC]
05 s281 #1401~ Sold
  #126
Old 01-26-2012
I am experiencing a bit of a traction problem.
05-653 Mineral Grey
  #127
Old 01-26-2012
Cool
I will not be able to go to the track until late May. We have not had so much snow in Iceland like now for many years. Hopefully it will be gone before the summer. If not I just have to read about yours and envy you guys
Hilmar Jacobsen,
1966 Mustang Coupe
Reykjavik Iceland
  #128
Old 01-26-2012
Ill go tomorrow after work, Im not running my car till the turbo is installed, my brother is running his '10 Camaro SS 6spd, hope he breaks into the 12s.
  #129
Old 01-26-2012
mosaleen's Avatar
mosaleen mosaleen is offline
Nice times Iceland,,, I to had problems with my Gates belt, If you are running the stock 2.87 Saleen S/C pulley you will be fine running the Gatorback belt, but if not take a look at it when you first start it up cold.
See if the belt comes off towards the front of the S/C pulley if so go to Dayco Poly Grip belt. The Gator back belt ribs are .85 wide and after market S/C pulleys except Saleen's and Metco's are .65 so the belt rides on top and will eat the front two rips off in time.
Scott
3:73 gears, Watts link Gen II
  #130
Old 09-03-2012
MichaelClark MichaelClark is offline
Default Any of you S/C guys run your cars?
Despite what oil companies and quick-lube shops often claim, it's usually not necessary. Stick to the service intervals in your car's owner's manual.
  #131
Old 09-03-2012
If your supercharged, you should follow the severe duty schedule in your manual as well.
