Q: 2002-2004 Extreme Heads
What heads did Saleen use on the Extreme models, all I've seen was on the info specs is aluminum heads. Reason I'm asking is I'm thinking about porting my heads. Wondering if it would be worth the hassle and money for the gain. I would like to keep the same heads to keep the originality of the car. Although heads are pretty much hidden under the valve covers.
94 Mustang GT 02 Saleen Extreme 02-0012 |
Saleen ported the heads. If your looking to add more power, have the intake elbow where it meets the blower unit ported. Also, add a larger throttle body. You could also go smaller on the blower pulley, it appears in your most recent pictures its near stock size.
89-122 95-104 R code 03-15 E |
Oh ok..I wasn't sure what they actually did to the heads. I figured they would upgrade them. Supposedly the car came with a bigger accufab throttle body in it already so i might just do that then. I was just trying to see my options. Thanks
Honestly, there are alot of items that will yield you good power on your Extreme. If you open the hood and look at the follow size tube from fender to throttle body, it shrinks down pretty good, then is opened again to the elbow intake. Both paths can be made larger, one by porting and the other by larger TB. Course once you add air, then your blower will want to supply more in terms of a smaller pulley. Then your motor will desire more fuel, so injectors will need fuel pressure turned up, etc....its just a fun game too play. My extreme did 470 rwhp 474 tq, and there is still plenty more in it if i want, but it breaks them loose sometimes in 3rd which can be an eye opener.
