Small Bumper Light Question
Is it possible to change the bulbs inside the small circular housing right next to the headlight?
I want to change the orange blinker bulbs to stealth bulbs that will light up orange but wont make the lense look orange when they are not lit but I cant seem to get the old bulb out of the housing...I tried to twist it out but I just ended up breaking one of the tabs on the light and it never budged. Is it a sealed housing or does the bulb come out from the back and can be changed? I want to change the blinker not the other small white bulb in there, just the orange one
2000 SVT Lightning 2003 Saleen S281 S/C Speedster #261 (Sold) 2007 Saleen S281 S/C Scenic Roof #542 2007 Saleen S281 S/C Coupe #235 |
Right: http://cgi.ebay.com/ebaymotors/02-08...item1e66baabe7 Left: http://cgi.ebay.com/ebaymotors/02-08...item3f0db1ef69 |
Mine must be stuck, I tried to twist the back of the housing off to change the bulb without taking the bumper off of the car and one of the tabs broke off and it didnt budge. It would be easier to explain if I had a picture of the back of the housing but the part that the tab broke off of is the part that the plug is connected to. I undid the plug and tried to twist the backing off and it did not work on either side. Yours just twisted off and you changed the bulb?
As long as I know that they are supposed to twist off then I will just keep prying on them until something gives but I got nervous when the tab broke on the backing of the light and it still hadnt budged. I started thinking maybe they are not removeable and I am just busting them up for no reason trying to twist them off lol
Well I was able to get these off but I ordered 3157 Bulbs and it appears they are not 3157 bulbs....does anyone know the bulb number for the turn signal? It has a round bottom and twists into place to lock in
You need an 1156. 1157 and 3157 are dual filament bulbs for brake lights. the 115x are round bottom and the one you need, the 315x are mostly for domestic vehicles with the plastic flat bottom connector.
Ahh thanks, I guess I should have asked before I bought bulbs, I dont know why I assumed they were 3157's. 1156 looks like the ones I just took out of the housing. Thanks.
Do you happen to know the bulb number on the smaller bulb that is in the same housing? It lights up a similar color to the headlights when turned on
Yeah thats a 194 wedge type bulb.
