Q: Aftermarket Shifter Options? - 2001 S281
Hey guys,
I'm considering putting a short throw shifter in my 2001 s281 and was wondering first if my year is a T-45/5. Also is it going to make a difference and which brand would be the best way to go. Thanks! |
My 2001 has a 3650.
I have an MGW in my car. Best in my opinion. The handle attaches to a splined shaft and can be rotated 360 degrees to put the handle in the best position for you. I had a Steeda Tri-Ax in my turbo Contour SVT. That was nice, but for a Mustang MGW is my choice.
2001 Saleen S281-SC Oxford White #01-0720 Fully Forged Rebuild 6/14 Series IV w/ pulley boys 2.8 pulley Trikpony Intercooler Heatshield Mosaleen Idler Pulley 42# injectors Supercar fuel pump w/ wiring mod 90mm MAF 75mm Throttle Body NGK Tr6 BBK O/R X-Pipe 13" Cobra front brakes MGW shifter 7" DVD player 376hp/395tq Series I gone!! Former-2000 Contour SVT T3/T4 TURBO-315 fwhp! |
MGW is the best in my opinion, I have had them on my T45 and my T56. Smooth and doesn't have the notch feeling like others. Just depends on what type of feel you like.
Check the code on the door sticker to see what should be in your car. 2001 is the model year they did a change over from the T45 to the 3650.
You can't go wrong with MGW and it's worth the money.
1994 Mustang Faleen aka Carbon Copy D1 supercharger and Water/Methanol Injected 849rwhp and 752rwtq SAE |
They are correct, I would go with MGW. When i bought my car it had a Steeda Tri Ax in it. Its pretty much clunky and makes alot of noise. Its not as smooth as the MGWs.
94 Mustang GT 02 Saleen Extreme 02-0012 |
